It is currently Fri Nov 06, 2026 7:04 pm
Vehicle: 2011 jimny
Post Posted: Tue Oct 16, 2012 8:44 pm
hey well today i tryed fitting my new jimnybits lift and found 2 things witch made me stop and put back together :deadhorse:
1.the shims u get to put into the bushes one fits perfectly with the bolts with no play but the closes other one had a little play in it. still alright to use??
2. the top bush on the rear springs wont fit into the mount where its suppose to its about 2mm to big. do i cut the rubber down to fit?
Post Posted: Tue Oct 16, 2012 9:11 pm
Lol I hate when witches fly in and stop me from fitting a lift.
Just stirring, please ignore.
Suggestions below
I assume we're talking about the metal sleeve in the centre of a urethane control arm bush, and the bolt that goes through it. If so I think unless there's loads of play it should be fine. Pack a heap of grease in there to stop it clunking.
The mount can probably be spread a little with a pinch bar or some pipe etc. Otherwise, use a jack to force it in. The urethane will give a bit, and again smear grease on it to help it slide in.
Vehicle: 2011 jimny
Post Posted: Tue Oct 16, 2012 10:02 pm
haha always get them two mixed up smartarse :rofl:
anyhow i will try that tomorrow with alot a grease, other than them problems its relatively easy to change and the jimny bits coils a mean compared to stock :D
Post Posted: Wed Oct 17, 2012 6:17 am
top bush on SPRING? um are we talking about the shock? If we are... I had EPIC trouble getting that mofo in the rear mounts too. had to force it in with the jack, and even that was pretty damn difficult. took about 2 hours on its own to do that.
Are they the rubber bushes that come with the shocks?
MY BUILD THREAD HERE!!!!!
Post Posted: Wed Oct 17, 2012 6:53 am
Oh yeah I forgot to question that... ??
Post Posted: Wed Oct 17, 2012 8:04 am
oh good, i was hoping that.. Thought you might know something I didnt nutter.
BTW, love the hot witch...... Legs FTW
Vehicle: 2011 jimny
Post Posted: Wed Oct 17, 2012 8:10 am
haha sorry yes shock i mean .... was in a rush :lol: sorry for the confusion
will try bending a little tomorrow and see if that helps if not get the jack out
Vehicle: 2008 Jimny Standard As :-)
Post Posted: Wed Oct 17, 2012 8:34 am
Gave my rear shock mounts a :deadhorse: to fit mine in, it did the trick.
Good Luck with it
Post Posted: Wed Oct 17, 2012 12:09 pm
I didnt have any issues when changing my rear shocks :/ is it something to do with bigger lift or wht?
Post Posted: Wed Oct 17, 2012 12:12 pm
Just the shock bushes I think. Different brands = different bushes.
Post Posted: Wed Oct 17, 2012 12:17 pm
My jb shock bushes were hard to get in. I was a bit dogy nd sanded them down until they fitted.
Vehicle: 2011 jimny
Post Posted: Wed Oct 17, 2012 11:15 pm
well after hours this arvo bashing around i finally got the rear shock and springs in pompoms fingers crossed the fronts are easier :lol:
Post Posted: Thu Oct 18, 2012 6:55 am
Disconnect all shocks and jack the car up and your coils should fall out.
Rear is easier then the front to put coils in.
Vehicle: 2011 jimny
Post Posted: Fri Oct 19, 2012 5:47 pm
ok well i got it in all good now but it seems to be sitting alott higher than 2 inches when flexed the brake lines are pretty tight, hey jaykay what numbers where stamped on your JB 3 inch lift?
Post Posted: Sun Oct 21, 2012 5:09 am
The jimnybits 2" lift will look high till it settles down, this is my jimny when I first fitted the 2" jimnybits lift + 205/75/15 m/t.
http://www.bigjimny.com/
Users browsing this forum: Google [Bot] and 64 guests
