It is currently Thu Jul 23, 2026 6:50 pm
Post new topic Reply to topic  [ 36 posts ]  Go to page 1, 2  Next
Post Posted: Wed Jun 03, 2009 9:41 pm
Gday everyone I'm new to this forum so go easy on me ah :D
My 1.3ltr EFI is just about shat , she has many issues but most of them are bottom end , BUT , I have the oppurtunity of installing a 1.6ltr EFI Vitara motor in.
My question is do you need a adapter plate for the bell housing or do they just bolt in.
To me I see know reason for one but at the end of the day I dunno.
I don't want to waste me money in buying the 1.6 and find out that she don't fit , where I can spend the money and time and get this 1.3 bored out and fixed up.
What do you reckon?
Brad.
[img][IMG]http://i716.photobucket.com/albums/ww165/woody156_photos/Catho12_10_080511.jpg[/img][/img]
Post Posted: Wed Jun 03, 2009 9:45 pm
Welcome to AZ!! Nice looking Jimny too!!
Sorry, can't help with your q's :D
Post Posted: Wed Jun 03, 2009 10:01 pm
Thanks ScawnC.
She will be looking total different shortly.
Total over haul. 8)
Post Posted: Wed Jun 03, 2009 10:59 pm
A) yes, you'll need an adapter. The G13 and G16 use a (slightly) different bolt pattern.
B) don't bother getting the G13 rebuilt. The cost of doing it well will be far more than the cost of the 1.6 conversion, and it is likely to have a short life.
Use your head and the bottom end of the 1.6 EFI motor.You don't want to use the distributor, AFM and old school injection of the 1.6 vitara motor - the jimny is a whole generation more sophisticated.
After you get it done, make sure you get the A/F ratio checked on a dyno - the jimny computer may, or may not fuel the 1.6 properly. I'm sure it will drive OK, but it might not be right.
Post Posted: Wed Jun 03, 2009 11:13 pm
Thanks a bunch for your input mate.
The only problem is , is that I can't find anywhere for the past 2 weeks who makes these adapters.
Any idea where or who makes them?
Brad
Post Posted: Wed Jun 03, 2009 11:23 pm
Hi,
just a random thought,
if its an early jimny with a g13 block the conversion sounds comparitively simple,
however not sure how much work would be required if its a later jimny with the M13 engine, as when we did some work on a coily M13 conversion the gearbox from the g13 didn't line up with the m motor, and had use the m series gearbox.
Post Posted: Thu Jun 04, 2009 12:01 am
nissvit wrote:
Hi,
Yeah she's the Series 1 version.99 model with the G13bb donk.
I agree with you , I honestly don't think there would be much to do.
Post Posted: Thu Jun 04, 2009 12:07 am
You can get the adaptors from a bloke in UnZed. Not sure who he is but I've heard he's reasonable.
Post Posted: Thu Jun 04, 2009 12:10 am
I'll just keep searchin.
Post Posted: Thu Jun 04, 2009 12:17 am
benT is the fella. $200 inc postage.
Post Posted: Thu Jun 04, 2009 12:23 am
Gday shep.
Thanks for the info mate but can I find him on this forum or any other.
Thanks
Post Posted: Thu Jun 04, 2009 12:51 am
what is the comparison between a rebuilt motors claimed likely short life and an unknown condition second hand 1.6's life.
sam
Post Posted: Thu Jun 04, 2009 12:55 am
also if you kept the jimny injection you'd probably want to just swap the g13bb inlet manifold, rocker cover and everything to do with the cooling system onto the g16b, so that you don't have to change anything except for the adapter kit
Post Posted: Thu Jun 04, 2009 12:58 am
don't get too carried away g-man. its a little more sophisticated.....but not that much. the main difference is coil packs, and don't go thinking map sensors are a whole lot better that mass air flow sensors, they aint! (they are just a little cheaper and simpler for the manufacturer, while giving very similar performance results.)
tip - use the vit injectors.
oh...and i had a jimny with a 1.6..............yeay me.......... :woohoo:
Post Posted: Thu Jun 04, 2009 1:02 am
you could make a pretty cool motor from the two the more i think about it.
jimny inlet setup is so much cooler, well to me anyways
Post Posted: Thu Jun 04, 2009 1:03 am
How did she run?
Did you buy it like that or did you install it.
Post Posted: Thu Jun 04, 2009 1:05 am
ran good. but i also installed the 4 speed vit auto.
Post Posted: Thu Jun 04, 2009 1:06 am
Where did ya get ya adapter plate from?
Post Posted: Thu Jun 04, 2009 1:08 am
vitara boxes need no adaptors, but i did have to make a new cross member for the box as well as other stuff. but the jimny box should go well for a while.
Post Posted: Thu Jun 04, 2009 1:12 am
Yeah that's me other option I guess and put a Vit box in.
Post Posted: Thu Jun 04, 2009 1:14 am
Yeah, then you can go twin transfers..... :wink:
Vehicle: 85 SJ413
Post Posted: Thu Jun 04, 2009 1:20 am
Gday shep.
Thanks
Hey, that would be me you're looking for. I have just started lurking on here, and mainly post on O*terlimits :oops: . PM me if you want a kit.
I have one of my kits runnung in a customers Jimny. He used a G15a motor, with the Jimny manifold bolted on, using the Jimny loom and computer.
He did swap the injectors to the G15a ones, but they were a direct swap.
From feedback so far though, you will need a body lift, even with the lower Jimny intake manifold.
Ben
Post Posted: Thu Jun 04, 2009 1:27 am
BenT wrote:
Gday shep.
Thanks
Ben
Sweet thanks for finding me BenT.
I was hoping not to put a body lift in because it ain't part of me budget.
But I'll PM ya tomorrow night about it mate.
Roughly how much for adapter + freight to Newcastle Australia?
Brad
Vehicle: 85 SJ413
Post Posted: Thu Jun 04, 2009 1:38 am
Brad
$200AU - shipped to anywhere in OZ.
Should be a link in my sig with a pic.
And I should point out the kits only work with the G13 Jimny's not the later M13 powered ones.
Ben
WWW.ZUKPARTS.COM - Quality Suzuki Off-road Parts
Post Posted: Thu Jun 04, 2009 3:30 am
Can vouch for the quality of BenT's adaptor kit. Smicko and bloody cheap compared with Yank and other kits. Just fitted a G16A to my Sierra using it. Comes with good instructions also.
Post Posted: Thu Jun 04, 2009 11:35 am
:woohoo: Another Kiwi!! :lol:
Welcome Ben. I can also vouch for Bens adaptors. I fitted one on the weekend, very easy and looks like good quality stuff. I loved the machined studs :D
Body lift kits are cheap from just_cruizin too, also a good kit and easy to install (when he supplies the instructions)
Vehicle: '92 Sierra
Post Posted: Thu Jun 04, 2009 6:59 pm
Yep got Ben's adapter in mine. Its good kit. Also Ben I like how you spelt outers with an asterix in there. Auszookers doesn't have a swear filter so you can spell outerlimits correctly. :p
Vehicle: 85 SJ413
Post Posted: Fri Jun 05, 2009 1:39 am
Thanks for the welcome and the good reviews guys.
Ben
Post Posted: Sun Jun 07, 2009 4:33 pm
I've eventually decided to go a full reco on me 1.3 ltr instead.
Roughly the same price with less hassle with a heavy duty clutch as well.
Thanks a million for all ya help everyone.
My hat goes off to all of you on this forum.
Fairdinkum this was my first post on this forum and was overwhelmed on how quick and helpful you all are.
Brad.
Post Posted: Mon Jun 08, 2009 5:40 pm
Use Daikin/Exedy (i think that's how it's spelt) clutch , and don't let them sell you a Swift one... :wink:
Users browsing this forum: Google Adsense [Bot] and 205 guests
