It is currently Fri Nov 06, 2026 8:27 pm
Vehicle: 90 hardtop and 89 soft top
Post Posted: Thu Oct 25, 2012 7:24 pm
Can you guys tell me the name if some build threads where they have 2 inch spring and 2 inch body with 33s. Thanks in advance.
Ps I only have seen bluesuzys
Vehicle: Drover pickup turk
Post Posted: Thu Oct 25, 2012 7:50 pm
Although no body lift and the build is only just beginning, Take a look at lachs lwb - viewtopic.php?f=4&t=33644
I like the tuna here
Post Posted: Thu Oct 25, 2012 7:56 pm
Mine did.
Post Posted: Thu Oct 25, 2012 8:04 pm
viewforum.php?f=4
Post Posted: Thu Oct 25, 2012 8:31 pm
I'm running 2 inch body and some well settled 65mm efs on ruf. I'm running 32's with eaze. There are a couple of pictures in my build thread which should be in my profile.
Sierra, 32's, Airlocked, 6.5'd, hopefully ruf soon
Post Posted: Thu Oct 25, 2012 8:34 pm
I have about 2.5 inch spring lift and 1 inch body lift for 33s
Post Posted: Thu Oct 25, 2012 8:56 pm
I have 2 inch body and flogged out leaves with big 32s just
Post Posted: Thu Oct 25, 2012 9:15 pm
Mine was 4" spring and 33's.
Vehicle: 4wd
Post Posted: Fri Oct 26, 2012 6:10 am
I'm in the process of 0" lift and 33's.
Watch out or you'll get sued.
Vehicle: SJ70 1993
Post Posted: Fri Oct 26, 2012 11:31 am
im the same so far just got to put new flares on
Post Posted: Fri Oct 26, 2012 7:17 pm
how do you get bloody 33s on with no lift?? that stumps me.
Post Posted: Fri Oct 26, 2012 7:26 pm
grinder welder
Post Posted: Fri Oct 26, 2012 7:33 pm
2" and 33's is the go.
Post Posted: Fri Oct 26, 2012 8:11 pm
I
I'll just put this out there again as a reminder.
35's. no lift.
There's almost no difference in labour between cutting the guards a little bit and cutting them a lot. Whilst that hardtop isn't setup exactly how I'd do it, it proves what's possible if you are willing to cut.
Post Posted: Fri Oct 26, 2012 8:16 pm
Road legal Steve?
Post Posted: Fri Oct 26, 2012 8:21 pm
Are 33's roadlegal in the 1st place Joeblow?
No
Your point is?
Post Posted: Fri Oct 26, 2012 8:33 pm
No
Your point is?
My point is cutting. Many signatories these days are very shy of vehicles that have severe cuts applied to them. Just bear in mind the when the authorities get involved.
:roll:
Post Posted: Fri Oct 26, 2012 8:40 pm
No
Your point is?
:roll:
Oh no, cutting, its just another thing on the list to go with the 33's.
Why stop there, that isnt roadlegal because of the colour either.
:roll:
Post Posted: Fri Oct 26, 2012 8:55 pm
hillbilly wrote:
if i can fit 33s on my lj (only 50mm ,body lift)cant see why a sierra cant do the same ....i run sierra diffs and springs......
Still here?....................ahh shit.
Whatever............I'll listen to Blue, he seems to have more of a clue to at least building a half decent rig.
Hillbilly, how do you get the front centre on the Sierra diff to clear the chassis rail of the LJ?
Post Posted: Fri Oct 26, 2012 9:11 pm
LJs have more space in the guards, well in the front anyway. I can't speak for the back as I don't have a SWB LJ here. The head lights are also closer together and higher up than a Sierra so there's no issue there.
Post Posted: Fri Oct 26, 2012 9:39 pm
The back has more clearance too.
Post Posted: Fri Oct 26, 2012 9:46 pm
How else Joe, with a hammer I'd say. Or maybe a chainsaw being he's a stick farmer.
Post Posted: Sat Oct 27, 2012 6:43 am
i got 2" springs extended shackles and big big guard chop....i clear 34s
Vehicle: Daisy
Post Posted: Sat Oct 27, 2012 12:25 pm
Will be going for a small guard chop (just going to take it up to the top of the wheel arches so maybe that's actually a big chop) but the plan is to do it properly, considering I'll be running 50mm body lift (have to) and 50mm spring then I think it won't be a drama with 33's
The flares will cover the guards properly so there shouldn't be a problem.
Users browsing this forum: Baz89 and 91 guests
