It is currently Tue Aug 04, 2026 12:18 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page 1, 2  Next
Vehicle: 94suzuki vitara
Post Posted: Fri Oct 26, 2012 10:29 pm
Hi everyone i have a 94 vitara 1.6 carby and i was just wondering if theres any cheap easy engine mods so i can get some more power. Or wat is easy swap engine thatll give me more power any recomendations?
Post Posted: Sat Oct 27, 2012 12:48 am
Cam, Weber and extractors, or swap in a G16B.
Post Posted: Sat Oct 27, 2012 1:12 am
Wat type of cam and webber
Post Posted: Sat Oct 27, 2012 1:21 am
Cam depends on your driving style and requirements: CAMS
A couple of choices on the WEBER: 32/36, while others have run a 36/36.
Post Posted: Sat Oct 27, 2012 1:34 am
Wats the difference in the webbers
Post Posted: Sat Oct 27, 2012 1:54 am
WEBER, if you spell it right, you could find what you need to know on a internet search!
Post Posted: Sat Oct 27, 2012 8:19 am
i believe this guy is a half a troll, he even copied another person's user name.
Post Posted: Sat Oct 27, 2012 9:23 am
Yea u neva guessed were mates and talk bout my name qat kind of name is atari
Post Posted: Sat Oct 27, 2012 9:41 am
at least i was original enough to come up with something different.
also learn to type... this isn't failbook.
Post Posted: Sat Oct 27, 2012 9:44 am
Who honestly cares about spelling ur not at a english exam.
Post Posted: Sat Oct 27, 2012 9:59 am
well for starters, the spelling of webber/weber would be one.
searching for webber brings up these
searching for weber brings up these
all i'm trying to say is put a bit of effort into your posts & people are more likely going to put some effort into giving you a decent reply, it's a 2 way street. :wink:
Vehicle: 4wd
Post Posted: Sat Oct 27, 2012 10:03 am
I have one of these webers. There great.
You have to get the air/fuel ratio right otherwise they blow a bit of smoke and run hot.
Watch out or you'll get sued.
Post Posted: Sat Oct 27, 2012 10:07 am
do you have problems with them flooding going up or down hill, mine only works well on flat ground. :?
Post Posted: Sat Oct 27, 2012 1:20 pm
When you ask a question on here I'm guessing you were looking for an answer that's helpful and is easy to understand.
If so, it's best to write a question that's helpful and easy to understand.
Good spelling and grammar, and being polite, gets better results from the internet.
Post Posted: Sat Oct 27, 2012 1:56 pm
It was a simple question wats not to get? and i wasnt the one who started juat after a quick easy answer, and sorry i pushed the wrong button sheesh its the internet so who cares ?
Post Posted: Sat Oct 27, 2012 2:04 pm
there is no such thing as a quick & easy answer... it's a bit like a quick question viewtopic.php?f=1&t=36599
southcotts out at wingfield can regrind cams another option is tighe cams http://www.tighecams.com.au/
Vehicle: 2010 Suzuki Swift Sports
Post Posted: Sat Oct 27, 2012 3:52 pm
I was going to offer something intelligent, but when I have to read your posts 3 times to figure them out as every 2nd word is misspelled or abbreviated I gave up. Put a bit of effort in and people may take you seriously. We don't like posts that look like a 14yr olds sms. You aren't charged for the length of your post here!
Post Posted: Sat Oct 27, 2012 4:16 pm
U try typing on stupid phones these days
Post Posted: Sat Oct 27, 2012 4:24 pm
Having owned both motors, the G16A and the G16B. I think its better to upgrade to a G16B, than stuff around with the other stuff trying to improve the G16A. The difference between the two is night and day IMO, and you'll have better economy with the G16B.
The G16B i had with 300,000kms was far better than the G16A with half the km's on it.
Post Posted: Sat Oct 27, 2012 4:39 pm
I would advise against doing a cam, extractors and weber carby.
As per the g13a/ba mods the main reason is the hp/$ increase will be atrocious.
A cam is quite expensive, considering all it does it tweak the power curve, not create more power.
Extractors may lose you power
Weber carby may use more fuel, as it may breathe better, and you have to get the jetting just right.
And you will have flooding issues.
Convert it to g16b, and enjoy much more power, and better fuel economy.
$/hp is probably one of the best mods.
You could maybe try a j18 or j20 , or even a h20 out of a gv if you want something different.
Post Posted: Sat Oct 27, 2012 4:46 pm
Thanks chop and jdk81
do you no how much killowats the G1616a puts out to the G16b?
And wats a good price to pay for a G16b?
Post Posted: Sat Oct 27, 2012 4:52 pm
I think 55kw -70kw
Post Posted: Sat Oct 27, 2012 5:26 pm
Ya g16a wasnt that bad was it? :shocked:
Post Posted: Sat Oct 27, 2012 5:27 pm
Thankyou:)
the only differnece between the two engines is one has DOHC right or is there more to it then that wat im trying to say is can i put a head of a G16b onto my G16a and will i notice the difference?
Post Posted: Sat Oct 27, 2012 5:32 pm
G16b is a 16 valve motor & you can bolt the head but you need to swap to G16b pistons, you're better off with a whole G16b donor vehicle cause you going to need the EFI & all the associated bits including a EFI tank or surge tank set up.
Vehicle: vits
Post Posted: Sat Oct 27, 2012 5:47 pm
And that particular G16B still pulls like a train with 340,000kms on it Armsup
Post Posted: Sat Oct 27, 2012 5:49 pm
Ok thankyou guys anyone no of a G16b donor in sa
Post Posted: Sat Oct 27, 2012 5:56 pm
Your old one was a step above and beyond the 1.3 it replaced, but the G16B's are better again. EFI helps alot, they're just a better package as a whole.
Post Posted: Sat Oct 27, 2012 5:57 pm
check gumtree & the auctions, personally it would be easier/better to sell up & buy an EFI one, the swap what mods you've done to the new one.
Post Posted: Sat Oct 27, 2012 5:58 pm
It loves it that thing! :peaceout:
Users browsing this forum: No registered users and 284 guests
