It is currently Fri Nov 06, 2026 5:08 pm
Post Posted: Thu Nov 01, 2012 5:29 pm
Ive accidentally removed this shift fork out of a sierra case and the little ball has fell out
Now i cant reassemble it. I cant get the shift fork back in because the ball is in the road. ..... Help please
Vehicle: 4wd
Post Posted: Thu Nov 01, 2012 5:33 pm
You'll need to get yourself another ball bearing.
viewtopic.php?f=5&t=36738
Watch out or you'll get sued.
Post Posted: Thu Nov 01, 2012 5:34 pm
The other rod has a dimple in it for the ball, move te other rod around till the ball sits back in further. Next, I sit the (currently out) rod partially in, put the other spring loaded ball in and with 3 hand push the ball in the hole, hold the case and move the rod through and back to position. Done!
Vehicle: 4wd
Post Posted: Thu Nov 01, 2012 5:35 pm
Haha, I miss read that as ball is on the road, as in it sprung out and you lost it.
Post Posted: Thu Nov 01, 2012 5:57 pm
^ you've lost it simbo!
Post Posted: Thu Nov 01, 2012 6:16 pm
thanks josh. i lined up the other shift fork and gave it a hit with the mallet Armsup
Post Posted: Thu Nov 01, 2012 6:51 pm
Armsup
Vehicle: Daisy
Post Posted: Thu Nov 01, 2012 11:36 pm
Another trick for anyone else to get the ball to depress (provided it's still in there and you want to switch between positions the fork can rest in) is to rotate the fork (this is easy) which pushes the ball back in, slide, rotate back, much easier than pushing it really hard!
Post Posted: Fri Nov 02, 2012 6:22 am
It wasnt the ball on the other side were you rotate the shifter and push in. It was the other ball what has the litlle spring under it. I had to push the other shifter right in, push the ball in with a screw driver while holding the shift fork in the hole and gave it a tap with a mallet.
Vehicle: Daisy
Post Posted: Fri Nov 02, 2012 6:37 am
Yeh I worked that out, just thought I'd put the info here for the next poor bastard who gets stuck :p
Good to see you worked it out though, sometimes it's okay to use the persuader!
Post Posted: Fri Nov 02, 2012 4:45 pm
Is there a special way to get the gearstick bush in past the pins?
Vehicle: Daisy
Post Posted: Sun Nov 04, 2012 8:14 am
IIRC if it's the lowrange one, there's two slots on it, put them down on the pins then it should flip over in there. It just rolls around the pins. Then just turn it sideways and put the shifter back in!
Post Posted: Sun Nov 04, 2012 8:28 am
X2
Post Posted: Sun Nov 04, 2012 10:41 am
X2
Nah was from 4wd products of ebay. Was hard as a rock. So had to neally demolish it to get it past the pins.
Users browsing this forum: Google [Bot] and 81 guests
