Ian,
To "verify" something you need to compare it to something else..
Would you like to post your measurements so that somebody can verify them or would you like someone to go and measure their car to get whatever details you need?
Jas.
I need someone to measure theirs as I have a 1.3 in place of the 1ltr as forgot to double check measurements before engine removal for alignment.
Thanks
I just did a quick measure. Mine is approximately 280mm from pulley center line to passenger chassis tail. I'm assuming your transfer is mounted in the stock location? If so I'd be more worried about aligning and squaring off your transmission output flange to your transfer input flange.
Thank you Hybrid
The engine is sitting approx same,I have the height measurments just needed to double check the centre before making engine mounts.
Thanks again.
Ian
Users browsing this forum: Google [Bot] and 146 guests
