It is currently Wed Oct 21, 2026 11:14 pm
Vehicle: MG410 1.6efi broken rear diff
Post Posted: Wed Jun 17, 2009 10:12 pm
Hi
Can anyone verify the measurements for the position of the crankshaft bolt from the inside the driver and passenger side chassis rail.
Thanks
Ian
Post Posted: Thu Jun 18, 2009 12:43 am
Ian,
To "verify" something you need to compare it to something else..
Would you like to post your measurements so that somebody can verify them or would you like someone to go and measure their car to get whatever details you need?
Jas.
Post Posted: Thu Jun 18, 2009 12:48 am
I need someone to measure theirs as I have a 1.3 in place of the 1ltr as forgot to double check measurements before engine removal for alignment.
Thanks
Vehicle: '92 Sierra
Post Posted: Thu Jun 18, 2009 1:06 pm
I just did a quick measure. Mine is approximately 280mm from pulley center line to passenger chassis tail. I'm assuming your transfer is mounted in the stock location? If so I'd be more worried about aligning and squaring off your transmission output flange to your transfer input flange.
Post Posted: Thu Jun 18, 2009 1:17 pm
Thank you Hybrid
The engine is sitting approx same,I have the height measurments just needed to double check the centre before making engine mounts.
Thanks again.
Ian
Users browsing this forum: Google [Bot] and 131 guests
