It is currently Fri Nov 06, 2026 12:18 pm
Vehicle: SWB sj70
Post Posted: Mon Nov 26, 2012 5:02 pm
Currently doing a baleno G16B and was wondering wich thermostat housing and hose combination people have used
Vehicle: 4wd
Post Posted: Mon Nov 26, 2012 5:05 pm
Suzuki swift housing. There are part numbers floating around my thread.
As for the hoses, next to nothing off the shelf. You will have to mix and match. Some go over the exhaust manifold and some including myself go under the intake manifold.
Watch out or you'll get sued.
Vehicle: SWB sj70
Post Posted: Mon Nov 26, 2012 6:10 pm
thanks man will have a look at your thread :)
Vehicle: SWB sj70
Post Posted: Sun Jan 06, 2013 8:53 pm
ok so the motor is in but it hits the vacum connector for the booster, what have other people done to fix this??
Post Posted: Sun Jan 06, 2013 9:51 pm
you can spin it around so it points up
 Profile YIM
Vehicle: SWB sj70
Post Posted: Sun Jan 06, 2013 10:49 pm
It already pointed up and it won't go any other way because of the plate on the back of the inlet manifold, I am pretty sure I need one from an xd/xf falcon if it fits
Post Posted: Sun Jan 06, 2013 11:23 pm
can you use jimny bits?
Vehicle: SWB sj70
Post Posted: Mon Jan 07, 2013 9:12 pm
hey cuzz i used a xf/xd one with a new grommet, fitted mint
Vehicle: 2018 DMAX
Post Posted: Tue Jan 08, 2013 9:19 am
My balena setup uses sierra hoses with some pipe under the intake. Hoses are trimmed to suit but makes replacment easy, instead of mixing up random hoses.
NOS Swift thermostate housing is the go, one of the new ones I purchased hit the firewall.
Vehicle: SWB sj70
Post Posted: Tue Jan 08, 2013 10:40 pm
Rogie, cheers mate I just got to run the hose to the heater core and to the bottom of the radiator and its done :)
Vehicle: SWB sj70
Post Posted: Thu Jan 17, 2013 9:02 pm
so can anyone tell me what they did for the hoses to the heater??
Vehicle: SWB sj70
Post Posted: Mon Jan 21, 2013 9:55 pm
Anyone???
Vehicle: SWB sj70
Post Posted: Wed Jan 30, 2013 10:25 pm
Ok so I am up to the wiring and was wondering what other connectors do I need apart from all the ones for the motor??
Users browsing this forum: Google [Bot] and 48 guests
