It is currently Fri Nov 06, 2026 11:39 am
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2  Next
Post Posted: Sat Jan 19, 2013 12:47 am
Every time I start my jim in the morning it blows smoke for about 5 seconds then goes away? Rings? Any ideas?
Online
Post Posted: Sat Jan 19, 2013 1:47 am
Valve stem seals most likely. :)
Post Posted: Sat Jan 19, 2013 5:53 am
X2 on that.
It's a common issue with the SOHC single cam head. My car smokes like a mofo until it's warmed up a bit, then doesn't smoke and doesn't use any oil from that point.
Unforunately, they are a bit of a PITA of a job to do. No $$ in parts, all labour.
Vehicle: 1987 Suzuki Sierra hard top
Post Posted: Sat Jan 19, 2013 10:33 am
I've goth the same dproblem with mine has just started doing it!
Where's the best place to buy new one from????
Post Posted: Sat Jan 19, 2013 11:09 am
Any auto parts store or engine rebuilder or head specialist will be able to supply a set of stem seals for a few dollars.
BUT...
If you need to ask where to buy them I wouldn't suggest you try fitting them unless you have someone who knows what they are doing to help you.
Post Posted: Sun Jan 20, 2013 10:35 am
Mine does the same thing, I'm not worried about it enough to fix it just yet
Online
Post Posted: Sun Jan 20, 2013 10:40 am
x2 it's not an issue at all, just a bit embarrassing.
Post Posted: Sun Jan 20, 2013 12:30 pm
mine did similar too - luckily it was under warranty and was fixed free of charge... turns out that the brand new stem seal had hardened right up - must have been a bad batch or something.
i can't stand having leaks, or smoke personally - its embarrassing and an easy way to draw attention from the police. Of course, if its only on startup its not so bad, but still, the OCD in me would want to get it fixed =)
Post Posted: Sun Jan 20, 2013 3:41 pm
Suzistore probably didn't do it an charged you for it mate.
To OP, like everyone has said. Valve stem seals
Post Posted: Sun Jan 20, 2013 3:43 pm
they don't do their own head work, they send it out... when they failed, they sent it back to the guy who did it who said he'd not seen stem seals harden like that before, replaced them and sent it back.
don't be such a hater =)
Post Posted: Sun Jan 20, 2013 3:57 pm
I'm just saying as part of an engine rebuild it's usually the sort of thing you'd replace.
Post Posted: Sun Jan 20, 2013 3:59 pm
like i said - they were replaced... but they went hard after about 2 months of driving.
either way, the point remains that if in a few years mine hardened up again i'd probably spend the $$$ and get them done cos it'd annoy the hell out of me.
Post Posted: Sun Jan 20, 2013 4:53 pm
I'm probably going to get mine done when the engine comes out again to fix another rear main, the bloke didn't do that right so it's free of charge, throw some coin at it and get it fixed
Post Posted: Mon Jan 21, 2013 12:35 pm
Would you guys think that Valve Seals could still blow smoke after 5 seconds????
Ive got 150PSI over all four cylinders on compression test still a little confused wether its valve steam seals apprently there pretty common by the sounds of it.Has anyone on here done them???
Cheers Rob
Post Posted: Mon Jan 21, 2013 12:37 pm
Yes - 5 seconds for sure. Mine will smoke almost continually until there's some heat in the motor to burn it off, then it's clean as a whistle. It also depends where in the cycle the engine is when it's parked. Sometimes you'll get almost no smoke, sometimes heaps.
Post Posted: Mon Jan 21, 2013 12:47 pm
Yer thats right sometimes i think its gone then sometimes i look behind and think :shocked: .
Might go and buy myself some new seals and have a crack installing them, if anyone has done them please let me know if theres any cheats???
Post Posted: Mon Jan 21, 2013 1:30 pm
No shortcuts, just do it like the Manual says, and make sure you have all the right tools. Just be aware that even for the Professionals it's a one or two day job to replace the $10 or $20 bucks worth of little seals. How long do you think it might take you the first time?
Vehicle: 85 ' Drover
Post Posted: Mon Jan 21, 2013 1:37 pm
I'd be inclined to take head off, drop it at a machinist, get him to pressure test it, replace the valve stem seals, valve grind if required, and clean it in the acid bath.
you get it back a few days later, throw it back on with a new VRS kit, clean everything meticulously while the head is off.
And then youve got yourself an engine that top half is in 100% condition.
Vehicle: 2012 jimny
Post Posted: Mon Jan 21, 2013 5:31 pm
if any of the perth guys who are good at head work(hahaha sorry it cracks me up everytime) are bored i have a head that could do with some new valve stem seals if they wanna swing over and help :rofl: its a suzuki but not my jimny or any other 4 wheeled suzi
Post Posted: Mon Jan 21, 2013 6:59 pm
Do this! There's just too much pain involved if you haven't done it before
Vehicle: Clown Car..
Post Posted: Mon Jan 21, 2013 9:34 pm
From learning the hard way.. dont do it half arsed..
I recently got a motor and fitted it on the word it was a good runner..(yet to fix the fella up for it.. and actually considering taking it out and returning.. a fucked motor is of no use especially when I need it as the zukes my daily!!)
Kicking myself.. should of just done a full rebuild on one of the others I have around.
Unfortunately my smoke isnt only just at start up.. :(
My guess is rings.. gets some serious back fires upon deceleration, and obviously the smoke upon acceleration and under load..
(the tapping is as the camera rattles against the passenger mirror)
Vehicle: Jeep
Post Posted: Tue Jan 22, 2013 3:45 am
I am guessing the camera is pointing backwards, towards the rear tyre... looks like the smoke is coming from underneath somewhere, is the exhaust shortened, or is there a hole in it ?
Seems to go pretty well, going by your acceleration, just smokey, which the cops will jump on... so how much was it ?
I would be getting a reduction in the asking price, and if he wont, give him the bloody engine back... :evil:
Post Posted: Tue Jan 22, 2013 6:48 am
Lol, yeah camera is pointing backwards... and I am running a side exiting exhaust... the tip, barely visible in front of the rear wheel...
acceleration isnt blistering.. but wouldnt say its bad either. it does get a bit of a hiccup and misfire when around 3.2k on the freeway. idle is eratic.. one set of lights, will need to keep your wits about you, as it drops and stalls out, the next set.. will sit a touch under 1k..
original price was 300.. but had to remove the engine from the donor vehicle in 35+ heat, and after lending them a hand with removal of other items gearbox, rear diff, wheel spacers(bastard to get off on a removed diff).. came to 250.
Post Posted: Tue Jan 22, 2013 7:23 am
Its certainly not looking good for the rings.
Perhaps a compression test is in order, and then when you get the results, put a bit of oil down each cylinder and compression test again.
If the results increase, then good chance its rings, if the results stay the same, then valve stem seals i guess.
Vehicle: LJ20 LJ50
Post Posted: Tue Jan 22, 2013 8:14 am
get one of these, and do it on the car. and also get two spare collets BEFORE you start. That way when you loose one you will not panic
http://www.ebay.com.au/itm/360195578730?hlp=false
Camels have nice toes
Post Posted: Tue Jan 22, 2013 11:31 am
Tzar
Cheers for the link might get one,
Vehicle: Jeep
Post Posted: Tue Jan 22, 2013 7:38 pm
Yeah thought so, so thats where the exhaust terminates... Ah ok, well $250 is a pretty good deal, even if it needs a bit of work... sounds like the carby is playing up, needs a carby kit, or an exchange carby...
Post Posted: Tue Jan 22, 2013 8:09 pm
Yeah.. exhaust exits infront of rear wheel.. as per photo..
just a bugger thats its so smokey.. Guess its rebuild time.. rather than just slapping a set of rings in it.. hard choice as the one that came out just needed new big end bearings(im assuming-was knocking)
sucks learning the hard way.. Quick fixes are NEVER quick.. or cheap!
Carby wise.. Iv still got my 4k carb on the old engine.. chances are that will make its way onto whatever ends up staying in the zuke.. Stockers have to much going on with them for my liking.
Vehicle: Jeep
Post Posted: Tue Jan 22, 2013 11:33 pm
Yep, we all learn by our mistakes, and doing things on the cheap, they can be cheap learns, or expensive learns, you got off fairly cheaply this time... :D
Post Posted: Thu Jan 24, 2013 4:27 pm
where there is smoke there is um....foot long flames... 8O :x
Users browsing this forum: No registered users and 55 guests
