It is currently Fri Nov 06, 2026 2:05 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2
Post Posted: Thu Jan 24, 2013 5:22 pm
You're complaining? :D
Vehicle: Jeep
Post Posted: Fri Jan 25, 2013 12:18 am
foolsp33d wrote:
where there is smoke there is um....foot long flames... 8O :x
Me thinks your carby is running a bit rich, and the timing is out... 8O :lol:
Vehicle: 1987 Suzuki Sierra hard top
Post Posted: Sat Jan 26, 2013 8:13 pm
Just thought I'd update, replaced the valve steam seals took 7 hrs but its not too bad of a job to do no more smoke I'm one happy camper :)
Vehicle: Jeep
Post Posted: Sat Jan 26, 2013 11:58 pm
:woohoo:
Post Posted: Tue Jan 29, 2013 4:47 am
Took the head of my 86NT, was blowing smoke on deceleration....valve stem seals OK..the pvc valve was blocked up.
bye
Post Posted: Tue Jan 29, 2013 6:39 am
You Can Say that Again MACDADDY!! :)
Vehicle: Jeep
Post Posted: Tue Jan 29, 2013 4:54 pm
bye
The PVC Valve often gets overlooked, and they can block up pretty easily, good that you found it, just a pita that the head is off... :D
Post Posted: Wed Jan 30, 2013 6:14 am
I've Got 2 PVC Valves on my zook One Is Blocked And The Other i Can Blow Through it And Suck ???
I Thought PCV Valves are only supposed to Be One Way Valve on most Earlier Cars??
Vehicle: Jeep
Post Posted: Wed Jan 30, 2013 6:25 am
As far as i know, yes, they are only one way, as they are meant to regulate crankcase pressure, so if it worked both ways, it cant maintain the pressure... If it is a 2nd PCV valve, and not something else, it sounds like its frucked too...
Post Posted: Wed Jan 30, 2013 1:34 pm
Yer i thought So, Ill Get some New Ones I think thanks.
Vehicle: 85 ' Drover
Post Posted: Wed Jan 30, 2013 2:50 pm
Sometimes they come good with a good clean in some petrol, the oil gunks them up.
The ones i have palyed with are just a ball bearing type non return valve, not alot to them.
Post Posted: Thu Jan 31, 2013 6:37 am
Thanks for your input Drover Dave I Might play around with them on my spare motor cheers.
Users browsing this forum: No registered users and 55 guests
