It is currently Fri Nov 06, 2026 11:59 am
Post Posted: Tue Jan 29, 2013 4:18 pm
I am just wondering what you have to do to put a vitara manual gearbox into a 92 wt Sierra as my gearbox is about to explode and this will be the second one that I have stuffed I was just looking for an upgrade
Pics and links would be great but any help at all is still good :) or what gearbox I Could put in it that is stronger ???
Post Posted: Tue Jan 29, 2013 4:24 pm
Massage the tunnel, make a new gearbox mount, get the jackshaft shortened.
I don't have photos sorry, but it's a fabrication job.
Do you already have a 1.6? if not you'll need a "lucky 13" adapter.
Post Posted: Tue Jan 29, 2013 4:27 pm
i'd be putting a AW4 auto in considering the rest of your set up.
Post Posted: Tue Jan 29, 2013 4:30 pm
Yea is it hard to set up and what about clutches and stuff and is it fully computer controlled ???
As steve said, Crossmember and jackshaft. Tunnel will need widening, you can remove the remote shifter with a little work, and you will need a 1.6 flywheel and clutch.
Post Posted: Tue Jan 29, 2013 4:32 pm
Why go aw4 auto ???
Post Posted: Tue Jan 29, 2013 5:04 pm
Because they bring teh awesome. :D
Post Posted: Wed Jan 30, 2013 9:00 am
How hard are they to put in? ?? What sort of box are they? ??
Post Posted: Wed Jan 30, 2013 9:08 am
It's going on a GTI motor... That's what he was running on Saturday...
Post Posted: Wed Jan 30, 2013 9:13 am
Not as hard to put in as they are to make work electronically with the gti mmotor.
4speed auto
Post Posted: Wed Jan 30, 2013 9:17 am
What about the gearing between the sierra manual and vitara manual are they almost the same? ???????
Post Posted: Wed Jan 30, 2013 9:19 am
I'm thinking I might just go manual cause when I turbo it it Will be gay to have a boosted auto
Post Posted: Wed Jan 30, 2013 9:25 am
Gearing in both 5sp are very similar.
Post Posted: Wed Jan 30, 2013 10:04 am
Ok good I bought the vitara box had the transfer on the back?
Post Posted: Wed Jan 30, 2013 10:17 am
yeah, chuck the transfer :wink:
Post Posted: Wed Jan 30, 2013 10:23 am
Ahh ok how do I do that can I run twin transfer? ?
Post Posted: Wed Jan 30, 2013 10:24 am
Is it stronger than the transfer I have now? ?
Post Posted: Wed Jan 30, 2013 10:31 am
Arent you SPOA on hilux diffs and 35's?
Post Posted: Wed Jan 30, 2013 10:38 am
Yea I am
Post Posted: Wed Jan 30, 2013 10:39 am
I was just thinking can I adapt a twin hilux transfer onto the vitara box the I Will have low low and ot Will be Realy strong is there a kit? ??
Post Posted: Wed Jan 30, 2013 10:41 am
If you are considering toyota transfers or double transfers, buy this and a yota box.
http://www.trailtough.com/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=214&category_id=13&option=com_virtuemart&Itemid=53&vmcchk=1&Itemid=53
Post Posted: Wed Jan 30, 2013 10:47 am
Then low low Will be like 8.5/1
Post Posted: Wed Jan 30, 2013 10:56 am
Did you buy a manual box?
Seperate the gbox from the transfer, Motor/gbox adaptor plate, new gbox mount, wider tunnel, different shifter position through floor, I'm not sure about jackshaft to sierra transfer.
You don't drive it hard enough for lux stuff
Post Posted: Thu Jan 31, 2013 8:32 am
How do adapt the gearbox the the gti engine and to the transfer? ?
Post Posted: Thu Jan 31, 2013 9:21 am
Users browsing this forum: No registered users and 23 guests
