It is currently Fri Nov 06, 2026 6:22 am
Vehicle: Suzuki Grand Vitara
Post Posted: Tue Jan 29, 2013 7:29 pm
Can someone please tell me the size/spec of the bolt that holds the Heim Joint to the bracket on the diff.
It's the Camini 3" lift fitted to my Vitara.
Cheers,
Dave
Post Posted: Wed Jan 30, 2013 5:57 am
viewtopic.php?f=5&t=8591&hilit=calmini+rose+joint
Post Posted: Wed Jan 30, 2013 7:30 am
I must not post up what I want correctly, I sent a email to Calmini as well and got the wrong info.
I know the Heim Joint size, I need a bolt to attach it to the diff, bolt size and the shoulder length.
Will have to take a guess.
Post Posted: Wed Jan 30, 2013 7:32 am
Measure the hole. Ill take a stab at 1/2"(12.7mm)
Post Posted: Wed Jan 30, 2013 8:23 am
Will do can measure the Heim Joint hole and measure the length of the bolt under the Vit.
Post Posted: Wed Jan 30, 2013 9:38 am
pull it out, take it to a bolt shop... job done? :?
Post Posted: Wed Jan 30, 2013 9:59 am
Heims are normally the same size bore as the thread, so if they are 3/4 thread I'd assume they need a 3/4" bolt
Post Posted: Wed Jan 30, 2013 10:12 am
it's been a while since i had my junk apart but i'm sure the 2 spacers on the heim joint are stepped to locate in the hole & reduce the bolt hole size. hence the suggestion of removing it & taking it to a bolt shop.
Post Posted: Wed Jan 30, 2013 10:25 am
If it has a misalignment spacer i would assume the 1/2.
But if they dont the i would agree royce.
Post Posted: Wed Jan 30, 2013 10:31 am
it has a spacer
Post Posted: Wed Jan 30, 2013 10:40 am
That is one of the things I wanted to check.
The Vit is going in for some maintenance and I have to have all parts ready to go, I can't have the car taking up space at my mates workshop while I run around chasing parts.
But I might have to ask another mate if I can use his shed to take apart the car.
Post Posted: Wed Jan 30, 2013 10:45 am
you have a 2nd car from memory?
you could do this in your driveway.... remove bolt, jam a screw driver in the hole to stop the diff moving around too much, take bolt to bolt shop & get a replacement, come home & refit original bolt.
post up the spces on the new bolt, take car, new bolt & all the bits you want to your mates work shop & get him to do his thing.
job done.
Post Posted: Wed Jan 30, 2013 11:01 am
I thought I would have to have the chassis on work stands so I could move rear around.
Spare car is not a problem, will give it a go.
Post Posted: Wed Jan 30, 2013 11:09 am
put a jack under the the diff to support it, just before the pinion. you might need to either lower or raise the jack slightly to take the load off the bolt.
i removed & replaced mine without taking the wheels off when it broke.
Post Posted: Wed Jan 30, 2013 11:10 am
* common sense says to chock the wheels too. :wink:
Post Posted: Wed Jan 30, 2013 11:13 am
Cool, Thank you.
Post Posted: Wed Jan 30, 2013 11:17 am
I have had to lift a car off my next door neighbour, because he didn't chock the wheels before removing the tail shaft.
Post Posted: Wed Jan 30, 2013 11:21 am
hahhaha, he should have left the hand brake on... unless it was a trans brake, then he's stuffed. :lol:
Post Posted: Thu Jan 31, 2013 6:43 pm
Got another email from Calmini - 1/2" diameter x 3.5" long bolt.
Post Posted: Thu Jan 31, 2013 6:59 pm
cheers for sharing that one & it saves you have to pull it out to check. Armsup
Post Posted: Thu Jan 31, 2013 7:06 pm
Bewm Armsup
Post Posted: Thu Jan 31, 2013 7:10 pm
SierraDan wrote:
Bewm Armsup
+1 E-reps to Dan, nicely called 8)
Post Posted: Sat Feb 09, 2013 12:49 pm
Had the car apart last week and removed the heim joint and went to fit the new one, they sent me a BLOODY left hand thread.
Users browsing this forum: No registered users and 117 guests
