It is currently Fri Nov 06, 2026 12:47 pm
Post Posted: Tue Oct 11, 2011 1:49 am
So finally got myself a cheap ass 9500lb electric winch to replace my well worn and very time/energy consuming peanut handwinch and hopefully have it installed before I head up north for the wet season
Needing some inspiration in the form of how peps have mounted there winches weather it be in a bar or in a custom made cradle. So if you would kindly share some pics and info on your setup that would be great!
Cheers Dan!
Lil Foot!
Post Posted: Tue Oct 11, 2011 2:23 am
My winch is mounted into an ARB bar, but something to consider is where you mount your solenoid box. I have mounted my aftermarket solenoid box on the firewall on the left hand side of the below pic, behind the battery... And i have an in-cab winch in/out switch just behind the indicator stalk, mounted on the dash.... hope that helps Dan.
Post Posted: Tue Oct 11, 2011 3:12 am
Cheers mate!
I will be aiming to mount my solenoid box inside and away from engine heat and dirt and grime etc.
Would you have a pic of how the winch is mounted? I haven't actually seen a winch mounted close up on a sierra yet.
Lil Foot!
Post Posted: Tue Oct 11, 2011 3:16 am
I'll have to go out to the shed... hang on a minute and i'll post up some pics...
Post Posted: Tue Oct 11, 2011 3:25 am
looking at doing this at the moment aswell jrzook
ive been looking at these
http://auszookers.com/index.php?name=Fo ... ight=winch
if you have any other ideas am very interested in seeing them also
93 sierra 2"spring2"body 31,s & 4.9s
Post Posted: Tue Oct 11, 2011 3:27 am
My winch is a 6000 pound premier. Because of this we had to do some booty fab on the bar to make it all work... It's really hard to take good shots, so I hope you understand whats going on...
Post Posted: Tue Oct 11, 2011 3:30 am
Not sure If this is what you want
9500lb winch is mounted with four bolts with the fairlead bolted above the bottem winch bolts
Had to redrill two new holes for the fairlead
Vehicle: Coil Sierra
Post Posted: Wed Oct 12, 2011 11:18 am
custom winch centre
Mounts inside the chassis rails, then again around the round tube between each chassis rail.
Winch then mounts flat on winch centre.
Post Posted: Wed Oct 12, 2011 12:51 pm
Thanks a heap for the pics guys! Keep them coming! They are giving me good ideas 8)
Lil Foot!
Post Posted: Wed Oct 12, 2011 9:46 pm
I really like want33's setup
http://www.auszookers.com/index.php?nam ... =winch+bar
sheps/balls mounts look strong as fuck
http://www.auszookers.com/index.php?nam ... c&start=90
I'm trying to find a photo of built4thrashings which I liked too.. He had pipe through the x-member and then the bar held back onto that with U bolts and a brace, as well as std mounts.
http://s22.photobucket.com/albums/b316/ ... G_6944.jpg
I think Dank sells winch cradles?
Vehicle: Zookless
Post Posted: Wed Oct 12, 2011 10:26 pm
Post Posted: Thu Oct 13, 2011 12:20 am
is that bar only held on by 4 bolts???
thats how i am going to mount mine will this be strong enough?
Post Posted: Thu Oct 13, 2011 1:34 am
CairnsZook wrote:
I really like that bar!!!!
TOP WORK
Vehicle: Zookless
Post Posted: Thu Oct 13, 2011 3:24 am
Yes, just 4 bolts through the ends of the chassis rails with crush tubes as well.
It has proved strong enough so far, although I feel it should have additional mounts...
Post Posted: Thu Oct 13, 2011 5:18 am
Add something that goes around the crossmember and sleeve the inside of the crossmember
Vehicle: Suzuki SJ70 & SJ51T
Post Posted: Thu Feb 07, 2013 1:38 pm
The winch only bolts to the cradle with four bolts any way
Post Posted: Thu Feb 07, 2013 4:24 pm
Well since this has been bumped back up I may as well dump in how I ended up mounting my winch. Ripped from my build thread:
Started a winch install finally! No more mega hand winching for me woooo!
first step find some thick wall pipe and jam into chassis
Then scourer the back yard to find some steel. Found this! 8mm angled bracket that was being used as the shed ramp!
Chop it a bit and make it fit like this. Over the cross member. Trim front clip for winch
Bolt through cross member and tube with 10mm HT bolts
Check if 9500lb winch fits
It''s a pretty snug fit and doesn't protrude much. Need to throw on a few more brackets and chop the bullbar to fit. Bullbar will only sit around 10mm further out than stock 8)
Alloy bar with the winch and new mounts has been moved 10mm forward but around ~15mm upward which has given me better approach than before!
Still got a bit to do but it's nearly all sorted!
Final winch support cradle. It's a 2 piece bolt together design for ease of mounting the bloody thing. Only welding required was the side supports to stop fore/aft flexing.
Finished cradle installed with a lick of paint.
Additional mounting using the bullbar as part of a stressed member for lateral support.
Fairlead mounted and done!
Decided against installing the solenoid box out front above the winch in all the weather and crap so mounted it underbonnet via a bent alloy bracket. All wiring mounted by stainless p-clamps to keep it neat.
Dan
Vehicle: Zookless
Post Posted: Thu Feb 07, 2013 5:32 pm
Very nice Dan. Are you going to run the wiring to a switch inside the cabin?
Post Posted: Thu Feb 07, 2013 7:07 pm
That's the plan when I get around to it :)
Post Posted: Thu Feb 07, 2013 7:11 pm
Bladdy worth it Dan!
Vehicle: grey. has milk crate.
Post Posted: Fri Feb 08, 2013 1:53 pm
has anyone ever seen a mid-mounted wich in a sierra? I've not been able to find anything after a bit of an interweb search.
Post Posted: Fri Feb 08, 2013 3:32 pm
There's pics of a mid mounted high mount by GSteve, pretty sure it's in the for sale section or a high mount tech thread
Post Posted: Fri Feb 08, 2013 4:37 pm
Cap51z had a mid mounted high mount under the rear tray
Post Posted: Fri Feb 08, 2013 9:14 pm
Here's the pictures of the mid mount: viewtopic.php?f=7&t=33686&hilit=winch
And also for the in cab switch I'd recommend it be next to something solid you can hold on to if you have a bit of speed to your winch. Nothing worse than shooting up a hill with a fast winch, while steering one handed and trying to keep the switch pressed in and not be jerky on and off it. The windscreen bar of my cage was great for this purpose.
Post Posted: Sat Feb 09, 2013 4:37 am
rpmwrx wrote:
Is it my imagination, or is the cable on this winch coming off of the top (wrapped backwards)?
Users browsing this forum: No registered users and 55 guests
