It is currently Sun Aug 02, 2026 6:59 pm
Vehicle: 94 swb Vitara
Post Posted: Wed Mar 20, 2013 5:51 pm
Hi guys i have used the search tool & come to no conclusion, i own a 94 swb g16b vitara of wich i recently blew a fist sized hole in the front alloy housing, Ive since purchased a steel gv housing to swap over & i thought whilst im at it i'l fit a front locker ive looked at several forum threads wich say the 1510 lock-rite from a sierra will fit.
In searching for the best deal i received an email from low range off road wich states that i need the 1512 or 1532 & rocky road outfitters advised me that a 4 pin carrier from a pre 90's vit is required to make the 1510 fit.
ive also read that people are running 1510's in both the front & rear of their vits
Has anyone on here successfully fitted the 1510's & if so what exactly is required.
thanks in advance
miki
Post Posted: Wed Mar 20, 2013 6:12 pm
1510 will fit.
The difference is it comes with the pins used in the sierra diff. You dont need these pins when installing in a Vit center.
Post Posted: Wed Mar 20, 2013 6:51 pm
Built4thrashing wrote:
1510 will fit.
Thanks mate just alot of conflicting advice would the rear be the same case? & would your recomend fitting both or just the front?
Post Posted: Wed Mar 20, 2013 8:03 pm
I have a 1510 fitted in the Vit center i run in the front of GV and it works perfectly and i used to have a 1510 in the rear GV diff also.Rear Gv is same as 12bolt Vit.
Post Posted: Wed Mar 20, 2013 11:52 pm
If a 1510 fits a 7.25" vitara front, how can it fit an 8" vitara/ GV rear?
Post Posted: Thu Mar 21, 2013 1:39 pm
Side gears and pins must me the same size/shape
Post Posted: Thu Mar 21, 2013 1:44 pm
carrier bearings are the same so could be
Post Posted: Thu Mar 21, 2013 2:39 pm
It just does....
I had at one stage a 1510 and a 1512 lockright on the work bence and they were identicle......except the 1510 came with replacement cross pins.
Side gears are the same tooth count. Its only spline count thats different.
Users browsing this forum: No registered users and 308 guests
