It is currently Thu Nov 05, 2026 2:56 am
Vehicle: MG410
Post Posted: Thu Mar 21, 2013 9:55 pm
Is this possible?
I have read thread numerous threads but there is no distinction between 1.0L NT and 1.3L NT which add to the confusion.
I have a 1.0L NT sierra
I want to put 1.3L WT diffs in while retaining the current 4.11 diff ratios i have now. I already have bigger tyres than standard so the car is already geared down. Utilising the 3.7 ratios from the WT diffs will make this worse
Thanks
Post Posted: Thu Mar 21, 2013 10:09 pm
WT Marutis have 4.11:1 diff ratios in a 1.3l size. They're a bit rare, but they'l do exactly what you want. They must be from a WT Maruti, NT ones have 1l diffs. You cannot use the gears from a 1l diff.
Another option would be using Vitara front diff R&Ps. They're anywhere from 4.3 to 5.12. You could also use 1.3l NT gears which are 3.9:1.
Vehicle: MG410
Post Posted: Thu Mar 21, 2013 10:16 pm
LEGEND
Thanks for the info, exactly what im after.
Seems my only option then is to buy an aftermarket gearset or go the vitara R&P route as I do not want to reduce the ratio at all
Post Posted: Thu Mar 21, 2013 11:26 pm
No worries. If you go door knocking on farms it wouldn't be to hard to find a dead WT Maruti. :)
Post Posted: Thu Mar 21, 2013 11:27 pm
Good luck getting a farmer to part with it though. They'll fix it oneday you know. :wink:
Post Posted: Thu Mar 21, 2013 11:48 pm
I resemble that comment. :oops:
Do some work for them in exchange for stuff. Always works.
Vehicle: Suzuki Stockman '85 1litre
Post Posted: Fri Mar 22, 2013 8:30 pm
I'm so confused.
Whats a Maruti?
I got a Sierra Ute (I think, it was sold to me as a stockman) and I have no idea what is what any more.
Rich
Post Posted: Fri Mar 22, 2013 10:40 pm
A maruti is an Indian built LWB Sierra. They were sold here after Suzuki stopped selling LWB Sierras.
There are 2 diffent types of Stockman. The last models of LJ were called Stockmans. Marutis are also called Stockmans, supposedly only traybacks were called Stockmans but practically every styleside I've seen has been badged as a Stockman.
If the year under your name is right then your is not a Stockman as it's a genuine Suzuki Sierra LWB. Specifically, yours is an SJ41.
A lot of people call all trayback Suzukis Stockmans, it's a very common misconception.
Post Posted: Fri Mar 22, 2013 11:22 pm
The LAST stockman was an LJ. AFAIK, suzuki never released any sierra stockmans. These were sticker packs fitted at the dealerships to appeal to the farmers who had fallen in love with the light weight, agile and highly capable LJ stockmans. Its like how suzuki slapped the sierra badge onto the back of a jimny in a vain attempt to imply that the jimny was in some way comparable to the offroad capabilities of its predecessor.
Sierras build code starts with SJ, maruti build code starts with MG. Simple.
Post Posted: Fri Mar 22, 2013 11:40 pm
sideways wrote:
If the year under your name is right then your is not a Stockman as it's a genuine Suzuki Sierra LWB. Specifically, yours is an SJ40T.
Fixed for you.
While the Ute version of the LJ80 was a LJ81, and the 1.3 Sierra Ute was an SJ51, the 1.0lt Ute was oddly called the SJ40T.
Vehicle: MG410
Post Posted: Sat Mar 23, 2013 1:13 am
to add to the confusion
As per my build plate. My LWB NT maruti has the MG410WT chassis code but is complianced as a suzuki sierra
1993 model with factory f10a and 4spd
Post Posted: Sat Mar 23, 2013 7:27 am
Ah cool, sorry i'm new, god this is going to take some getting my head around.
So will the WT diffs go into the NT ute with the same mods etc? Actually i'll post up in another thread
Rich
Post Posted: Sat Mar 23, 2013 7:36 am
yea i just got a "suzuki maruti" as it says on the rego label, mine is also a 93 with same engine and box, nt with rubber flares and a steel tray, found a mg410wt badge in the glovebox, when did they start importing them with 1.3's and wide track diffs?
got some braced wt diffs with perches to suit nt and 5.1 gears to go in Armsup
Post Posted: Sat Mar 23, 2013 8:44 am
Never. No such thing as a factory 1.3L maruti in Australia.
Post Posted: Sat Mar 23, 2013 8:46 am
Rich
Yes. It all goes in the same, except that you will need the NT 1.3L u-bolts and spring plates, and you will need to change your driveshafts to suit the 1.3L pinion flange.
Post Posted: Sat Mar 23, 2013 10:59 am
Seen some advertised with wt flares that looked original, just assumed a few made it here
Post Posted: Sat Mar 23, 2013 11:18 am
nope they were all w/t 1ltrs
 Profile YIM
Post Posted: Sat Mar 23, 2013 11:31 am
The WT flares ARE original. But ALL Aussie delivered Maruti's are 1L motor.
Users browsing this forum: No registered users and 482 guests
