It is currently Wed Nov 04, 2026 5:36 pm
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
Vehicle: 1985 lwb sierra UTE
Post Posted: Sat Apr 13, 2013 6:24 pm
What I did was get 2mm sheat cut at 50mm , then I cut the hole tunnel out.
I followed the line in the floor with the grinder then with tunnel out of the car I fitted the tcase with the drum handbrake and fullsize rocktoy ring and just_cruising's tcase lift .
While the tunnel was out I welded the 50mm strip on and to the tunnel and double plated were suzuki had, I then just mocked it up trimied and adjusted and added in the side bits u see in the picture
Vehicle: Suzuki Stockman '85 1litre
Post Posted: Sun Apr 14, 2013 8:41 am
Thanks mate, I'm thinking of something very similar but tapered down just behind the handbrake so I can weld the back seeing as mines a ute.
Will work out the gearbox cross member first then see what I get to
Post Posted: Sun Apr 14, 2013 2:23 pm
This gearbox cross member has me a bit stumped, does anyone have any pics or links to show what others have done?
Looks like it might be a "cab-off" job to do new cross member
Post Posted: Sun Apr 14, 2013 7:07 pm
The only one I saw was definitely a cab off job but there's more the one way to skin the cat
Post Posted: Sun Apr 14, 2013 9:07 pm
You should be able to remove that section of crossmember lift the Tcase and make a new RHS section to come down below the front drive shaft (like a 1.3)
On the 1.3 when doing this mod you have to bash or cut out a little bit of the footwell so the drive shaft UNIs don't hit. I'm not sure about a 1L as they have a smaller transmission tunnel anyway...
Post Posted: Sun Apr 14, 2013 9:09 pm
I had to cut my footwell and add a whole section
Post Posted: Sun Apr 14, 2013 9:14 pm
Never had to cut the tunnel on mine for the driveshaft, but I had 3 inch bumpstops.
Users browsing this forum: Google [Bot] and 209 guests
