It is currently Thu Nov 05, 2026 11:00 am
Vehicle: 98 jimny
Post Posted: Thu Apr 18, 2013 9:13 am
As the topic says.
Pros and cons?
Vehicle: Sj70 tintop
Post Posted: Thu Apr 18, 2013 5:47 pm
is yours running hot?
Vehicle: 98 jimny
Post Posted: Thu Apr 18, 2013 6:33 pm
I've got a pin hole in her so after the weekend going to replace it usually runs at around half way
Post Posted: Thu Apr 18, 2013 7:34 pm
Best rad for a Jimny is a Jimny rad.
Vehicle: 98 jimny
Post Posted: Thu Apr 18, 2013 7:37 pm
Got offered a plastic one a steel one or a ally one and my plastic one got worn around where the cap goes on and started to leak so was thinking steel or ally
Post Posted: Fri Apr 19, 2013 8:11 am
are they not ally to begin with or are you not talking about just the fins.
Vehicle: 98 jimny
Post Posted: Fri Apr 19, 2013 5:02 pm
Full aluminium radiator
Post Posted: Fri Apr 19, 2013 5:51 pm
Sikmiconcepts has just ordered one for his from Malaysia, I am eager to know how it goes too, pm him maybe.
MY BUILD THREAD HERE!!!!!
Vehicle: 98 jimny
Post Posted: Fri Apr 19, 2013 5:58 pm
Does alliminium disperse heat better?
Post Posted: Fri Apr 19, 2013 7:13 pm
better then what? in relation to steel and plastic yes but the fins of a radiator are all aluminium anyway, unless you get a copper one and copper is far better then aluminium.
but changing the housing parts from steel or plastic to aluminium will have absolutely no advantage over another that i can see at all. The fins and tubes (the part that actually does the cooling) is aluminium anyway.
its would be more the design and shape of the tubes and fins that would have any advantage over another type. unless you were changing to a copper radiator, but they are quite weak compared to an aluminium radiator. you are far better off running a larger radiator or just sticking with the stock one that's designed for its motor.
Vehicle: 98 jimny
Post Posted: Fri Apr 19, 2013 7:17 pm
As far as I know it's the same as the stock but instead of the top and bottom being plastic it is aluminium
Users browsing this forum: No registered users and 92 guests
