It is currently Sun Aug 02, 2026 3:11 pm
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Tue Apr 02, 2013 3:09 pm
problem is there is no first time is free, youll get pulled up for a fine, not to get told take it off
Post Posted: Tue Apr 02, 2013 3:21 pm
I realise that.
Im happy to wear a fine. I'd be in the wrong after all with much time without problems, so yeah... call it LED bar tax lol.
Ive gone my whole driving life without getting slapped with a speeding ticket or any other fine, so im not too worried if i get a fine for that. gotta do my part to keep someone employed. Glass is half full Royce :)
MY BUILD THREAD HERE!!!!!
Post Posted: Tue Apr 02, 2013 4:13 pm
I can't believe some of the setups i seen over the long weekend, how people get away with 4, 3 or more huge spotlights up top is beyond me :?
Atleast a lightbar looks good and can be stealthy so it doesn't stand out.
Post Posted: Tue Apr 02, 2013 5:46 pm
Make a cover for onroad then they cant complain
How do jeeps get away with the factory roof lights on some models
Post Posted: Tue Apr 02, 2013 5:55 pm
da sirch eginge bungs ips sum cuntflicting texh one teh rooth lites
search.php
Matthew wrote:
Roof lights aren't illegal.
The ADR was changed a number of years ago, I believe it was due to pressure from Jeep, so they could release the kj Cherokee Renegade.
Zook_Fan wrote:
What I was told when I questioned a DOT inspector about roof lights was that there must be a series of switches to turn it on. It can't be on when the high beam isn't on, needs a separate switch in the cabin to turn it off and it is supposed to have another switch located somewhere that it can't activated from inside the car (under the bonnet or something). The purpose of the last switch was so you had to get out and pop the bonnet to turn the light on when you were off the road as they were not legal for on road use.
That was straight from his mouth, I've found nothing to back it up online.
Post Posted: Tue Apr 02, 2013 5:59 pm
Why can't this info just be readily available, instead of just heresay and lots of he said she said. None of the websites seem to be user friendly either
Vehicle: Suzuki Jimny 2009
Post Posted: Wed Apr 03, 2013 6:55 pm
I read the Vicroads regulations yesterday and they are certainly not easy to follow. My take on the situation is that an LED light on the top of the Bull Bar will probably be illegal as it restricts the drivers vision and could injure pedestrians. That is probably the same in all states. A light bar on the roof may be illegal (depending upon how the rules are interpreted) but if you put a cover over it and leave it disconnected until you are off road there will be no problem. Except of course as Christover states it will be subject to tree damage.
Post Posted: Wed Apr 03, 2013 6:58 pm
There must be a regulation allowing taxis etc to use work lights.
Post Posted: Wed Apr 03, 2013 7:20 pm
Christover
There are some exceptions in Victoria. If the lights were fitted in the factory (Jeep and FJ Cruiser) then that is OK (must have been lobbying by manufacturers I guess, and I expect the Taxi's have an exemption because they do not face forward but to the side and do not operate in conjunction with the normal lights.
Mike
Post Posted: Fri Apr 19, 2013 9:32 pm
interesting link about legality of LED light bars in QLD needing to be divided into 2 spot lights
http://www.tmr.qld.gov.au/~/media/Safet ... _lamps.pdf
Post Posted: Fri Apr 19, 2013 9:40 pm
Thanks Gus!
Post Posted: Fri Apr 19, 2013 10:05 pm
Apparently if you wrap a strip of tape around the centre of a single light bar, to divide the light beam into two, it will pass. :roll:
Post Posted: Fri Apr 19, 2013 10:32 pm
that's what the official doc from qld transport basically say
Post Posted: Fri Apr 19, 2013 10:54 pm
Its a stupid rule. What does it achieve?
Post Posted: Fri Apr 19, 2013 10:56 pm
it visually defines the light bar as 2 spot lights & therefore meets ADR's about having spot lights fitted in pairs. :?
Post Posted: Fri Apr 19, 2013 11:02 pm
yep. still not sure why having a pair of lights in necessary.
If the amount of effort that is put into legislating useless shit like this, was directed towards say......I don't know.....curing cancer, this world would be a far better place.
Too many rules, no common sense. :roll:
Post Posted: Fri Apr 19, 2013 11:04 pm
ADR's that is why...
Post Posted: Sat Apr 20, 2013 5:57 am
Yep! :roll:
Post Posted: Sat Apr 20, 2013 6:43 am
yep!
australia has some of the most crappo rules known to man......our pollies are to blame for us not getting the same spec cars as the rest of the world, we missed out on some of the better stuff due to our unique rules and small market, trying to protect the local car industry which has always been on life support has something to do with it
Post Posted: Sat Apr 20, 2013 8:08 am
So you don't think a motorbike is coming towards you?
Post Posted: Sat Apr 20, 2013 9:18 am
Haha a motorcycle with a 40" light bar :rofl:
Oh and I doubt anyone could stare at a light bar and tell it was separated by tape?
Post Posted: Sat Apr 20, 2013 9:31 am
Yes that is the reason for it in the ADR's. From a few k away you can't tell it's a 40" light bar, by the time they are close enough you can you know it's a car anyway.
You have to be able to tell it has been separated.
The width of such opaque dividing cover should be
enough to distinguish the arrangement as two separate light units. For example, the ability of an observer
standing 200m in front of the vehicle to perceive the light bar as two separate light units can be used as an
approximate guide.
So if you can't then you need more tape or can still be booked.
Vehicle: 93 Vitara -itty bitty lift
Post Posted: Sat Apr 20, 2013 10:01 am
or maybe the ADRs weren't written with 40inch light bars in mind.
the need for headlights in pairs an appropriate space apart is fairly obvious if you think about it,
and no regulation will ever be able to account for every situation and aftermarket product.
If you want a light bar run one and accept the slight risk, if you vehicle is massively modified and you
dont draw attention to yourself by driving like a fool then it probably wont be a problem.
if you dont want to do that then cover the bar on road.
Vehicle: 2006 Jimny
Post Posted: Sat Apr 20, 2013 8:21 pm
The person who i bought my Jimny of had to remove the fuse from the spot lights on the front because they weren't wired in to the highbeams. Apparently if they 'aren't functional' and are just there as cosmetic its fine and will pass roadworthy...
Post Posted: Sun Apr 21, 2013 3:21 am
Not in the ACT. Don't know about anywhere else but at my rego check all lights fitted had to work or be removed.
They told me what they should knock me back on but didn't. LOL.
Vehicle: WR250F/Jeep XJ
Post Posted: Sun Apr 21, 2013 11:00 pm
LED Light Bar Standards Vsi_hv250_driving_lamps.pdf
Here's the file to have a look at. Valid for QLD only, but most states will probably take up this stance on lightbars. Aurora are building some small clip on covers for their dual row and single row lightbars to deal with this.
Post Posted: Sun Apr 21, 2013 11:29 pm
yep, posted that up the other day :wink:
Post Posted: Mon Apr 22, 2013 11:39 am
I just attended the Rosehill camping supershow and spoke to a TJM Rep who said that ADR 13 stipulated that all fog and driving lights must be fitted in pairs...
The height was open to interpretation as all its states is that they must be fitted in pairs and must be mounted on the front of the vehicle. Where the front is... is once again open to interpretation..
What I have seen recently in regards to the larger size Light bars is blanking plates fitted over the 4 centre LED's giving the appearance of Two Light bars being fitted.. Not sure if its Legit but it might be a way around it..
They are comming out with Modular Light bars so Fitting them in a way similar to round spot lights are possible... but at $179 a pop.. a bit expensive for me...
Post Posted: Mon Apr 22, 2013 10:47 pm
oops haha
Post Posted: Tue Apr 23, 2013 4:39 pm
What I don't get is, they aren't supposed to be used when they could dazzle oncoming traffic, so why does it have to be distinguishable as a pair of lights @ 200m?
Users browsing this forum: Google [Bot] and 304 guests
