It is currently Wed Oct 21, 2026 7:10 am
Post new topic Reply to topic  [ 88 posts ]  Go to page 1, 2, 3  Next
Post Posted: Sat Jul 18, 2009 2:24 am
Okay without shocks it does not travel any better, i have a coily, sigh, and it is tough as nails, unsigh, but even though my arms are now unbreakable my front end is stiff as all hell, it just doesn't move it all.
Royce once said something about drilling the poly bushes out so ?
i have been offered an x-link setup kinda of thing ?
i have the factory bushes i would like to put back in to see if that makes a difference ?
what the shit else could i do that keeps my sexy onroad handling?
but honestly it is pretty much static, it only flexes down hill with all the weight on the car, i had it on the hoist at my mates and unbolted one shock and even with our whole weight on the wheel it only moved like an inch or two further down
oh and i am poor and willing to defeat all the shitness of a coily so others can win in the future
Post Posted: Sat Jul 18, 2009 2:26 am
and whats the difference in the arm setup of the jimny that makes it flex better ????? i have the same upper mounts what the crap
Post Posted: Sat Jul 18, 2009 2:32 am
thats pretty much flexed out STUPID SHIT
Post Posted: Sat Jul 18, 2009 3:08 am
lol my vitara has more flex than that.... maybe you should go IFS? :wink:
Post Posted: Sat Jul 18, 2009 3:21 am
yeah see it is freaking sad lol so over lifting wheels like a mofo
Post Posted: Sat Jul 18, 2009 11:11 am
get some softer bushes
but anything to give more flex will probably make it handle worse
Post Posted: Sat Jul 18, 2009 1:27 pm
remove the chassis and fit a pre 95 leafy job... lol ha ha ha
Seriously though... Longer travel=longer arms, shocks and springs
Post Posted: Sat Jul 18, 2009 2:35 pm
piss those freakin polly bushes off and use factory bonded bushes.
Post Posted: Sat Jul 18, 2009 4:51 pm
do you still have sway bars in, what are the brake lines like when flexing?
Vehicle: WR250F/Jeep XJ
Post Posted: Sat Jul 18, 2009 7:07 pm
pull out the front bolt on the radius arm on the driver side diff mount. Flex it up and see what happens. I"m guessing you will get maybe a couple of inches extra out of it.
coily's just aren't designed for flex. arms are too short. I'd be looking at lockers if you want to improve offroad ability.
Any radius arm setup will bind up on flex but it will keep it happy on the road. Maybe think about extending your radius arms and moving your chassis end mounts towards the centre of the vehicle.
I"d hate to say it but if you have the $$ buy a wrecked Wrangler and install the running gear into your coily. PLenty strong enough for a light sierra and 5 link front end will flex pretty well. 8O :wink:
Post Posted: Sat Jul 18, 2009 8:50 pm
im over coilys mate. constant trouble with mine nothing but money spent on fixing it. couldnt go wheeling today cause it decided to have a spaz attack. boooo. sorry im bringing negativity into your post by the way hahaha
Post Posted: Sun Jul 19, 2009 2:21 pm
ive lost my sway bar and brake lines are fine, i'm way past that point..
i think my best bet will be try get my factory bushes back in, it's really the only issue i have with my car there is nothing really left specifically coily related to go wrong. It's not so much an amount of travel issue it's a how easy it is to get it to travel, i suppose the roll stiffness or whatever you call it.
the poly bushes are good in the rear, makes it a bit more stable uphills, just need to coax those stupid control arm bolts out now :(
Post Posted: Wed Jul 22, 2009 2:36 am
Will be interesting to compare with the Jimnys on Saturday. Seems strange.
I have found that the Jimny flexes quite well although the front is hindered by urethane caster bushes. I think that coils should easily outperform leaves in stock form and both have their own limitations as they're modified.
Will be interesting to have a good look at it.
Post Posted: Wed Jul 22, 2009 3:45 am
There is nothing wrong with short arms. I have 80 series upper arms used as lowers, and GQ upper arms used as uppers on my linked sierra, and the range of movement is insane.
Its just the radius arms with poly bushes binding up.....
As you said its crap design :?
Post Posted: Wed Jul 22, 2009 4:31 am
hopefully i should have the factory rubber jobs back in there by saturday my shocks are still a bit short but they will get replaced when some money shows up.
sam
Post Posted: Wed Jul 22, 2009 12:45 pm
What about replacing the bushes with hiem joints?
Won't be very nice on road though.
Could your spring rate be too heavy? What springs are you running?
Post Posted: Wed Jul 22, 2009 8:31 pm
springs are heavy but that would not effect down travel so much, those heim joints are way to expensive and also i don't think they work so great in this arm setup.
I have honda crv 50mm lifted rears all around lol, did not think about jimny springs at the time because i originally had a longer coil over strut in the front/
Post Posted: Wed Jul 22, 2009 9:45 pm
Someone actually makes lifted spring for a CRV?!? 8O
Post Posted: Wed Jul 22, 2009 10:11 pm
yeah pedders :)
Post Posted: Thu Jul 23, 2009 2:36 am
I reckon those springs would be way to stiff as well, a CRV weighs around 1600kg and a soft top sierra is under 1000kg, you don't have the weight to flex them.
Get six 100kg front rowers in the coily and it might start to flex those springs.
Post Posted: Thu Jul 23, 2009 2:56 am
they don't seem to be that stiff
compress good in the rear.. and the front is heavier
lesspostingmorewheeling
Post Posted: Thu Jul 23, 2009 3:36 am
you're supposed to be in the car not under it when you're driving
Vehicle: 07 vvt jimny
Post Posted: Thu Jul 23, 2009 11:38 am
love ya zook mate :D:D i see ya getting around all the time i remembered ya number plates lol.
Vehicle: SJ80
Post Posted: Thu Jul 23, 2009 5:07 pm
My coily has rock friggin hard suspension in it also.
Apparently it has King springs in it.
I think they are probably an inch or so longer than standard, and hard enough to support 3 tonne!
Anyone managed to acquire a set of soft coil springs, that they are happy to recommend?
Post Posted: Thu Jul 23, 2009 7:26 pm
thanks mate! what are you drivin ive probly seen it?
also paul i am surprised your kings are so heavy duty the ones i used to have where hopeless it used to bottom out on my all the time. The springs i have in mine provide a good ride.
I think that the coily "Mike" has is running jimny springs...
Post Posted: Thu Jul 23, 2009 8:20 pm
Hey Saam whats the 88 in the number plate stand for?? It's not your year of birth is it??
Post Posted: Thu Jul 23, 2009 8:32 pm
I would say so :wink:
Post Posted: Thu Jul 23, 2009 8:51 pm
Holy crap. Thanx for making me feel old mate.:oops: :(
Post Posted: Thu Jul 23, 2009 9:54 pm
I'm old enough to have a child born in 88
Post Posted: Thu Jul 23, 2009 9:57 pm
yeah man 1988, 21st birthday next month
Users browsing this forum: Google [Bot] and 126 guests
