It is currently Wed Nov 04, 2026 1:13 am
Post Posted: Mon May 20, 2013 9:45 pm
When I accelerate everything is normal but when i take my foot off the gas and let it deaccelerate naturally (engine braking) it makes a loud clicking whirring noise form the gearbox area until i put the gas back on or push the clutch pedal in. Anybody had this problem? It went away for around 2 months but it's back again.
Post Posted: Mon May 20, 2013 9:56 pm
Good chance its clutch thrust bearing.
Gets mud in it,
which slowly kills them
Post Posted: Mon May 20, 2013 9:58 pm
uni joints can do similar
worn or broken transfer ans/or engine mounts.
Post Posted: Mon May 20, 2013 9:59 pm
Cat converters can come loose inside and do similar
Post Posted: Mon May 20, 2013 10:38 pm
the ends of my shoelaces some times rattle when i de-accelerate.
i'd be checking ALL uni joints, particularly the rear 2 & the 2 on the jack shaft.
Post Posted: Tue May 21, 2013 5:21 pm
Thanks guys, I suspected uni joints as well but them seem fine, anything in particular I should be looking for when checking them? There is very little free play in them and they don't feel stiff to move around either. Replaced my engine mounts a few weeks ago. Any way of checking or any other indicatiors it's the clutch bearing without talking the box off?
Post Posted: Tue May 21, 2013 5:27 pm
remove the tail & jack shafts & physically check the movement in the uni joints & to see if they're notchy at all.
Post Posted: Tue May 21, 2013 5:29 pm
I'll give that a go in the next few days
Post Posted: Tue May 21, 2013 5:41 pm
Unis can sieze on one axis, without it being obvious.
If this is the case, one axis will get very hot, enough to say ouch.
Or removing shafts and turning unis it will be obvious if seized.
Post Posted: Tue Jun 18, 2013 4:24 pm
Just an update, One of the UJ's on the gearbox to transfer box was a bit stiff, changed it and now it's all good. Thanks guys.
Post Posted: Tue Jun 18, 2013 5:00 pm
Users browsing this forum: No registered users and 98 guests
