It is currently Wed Nov 04, 2026 10:27 pm
Vehicle: Swb vitara
Post Posted: Sun May 26, 2013 9:16 am
I got a 89 vitara and got no power to the coil pack ? Anyone know
Post Posted: Sun May 26, 2013 9:31 am
check the fuse?
Vehicle: Swb vitara
Post Posted: Sun May 26, 2013 9:44 am
Done all that not fusses
Vehicle: vitara
Post Posted: Sun May 26, 2013 8:50 pm
crank sensor dude, the crank sensor tells your coil pack when to fire mate, hope that sorts it out for you,
(be nice if someone can help me with my lift kit,lol)
Post Posted: Mon May 27, 2013 6:35 am
well there aint much else between the key and the coil, assuming you checked there was power there and didnt just pull one out and go its ok
get your test light back out and start working back along the loom plugs till you find a point where you have power and fix the break
Vehicle: '94 Sj413, 1.6 baleno convert
Post Posted: Mon May 27, 2013 11:10 am
By coil pack I'm assuming you mean the ignition coil to the dizzy?
Post Posted: Mon May 27, 2013 11:13 am
coilpack as in coilpack probably.
i.e the 13bb, j20a, or g16b with no dizzys
Post Posted: Mon May 27, 2013 12:21 pm
Yeah I suspected but then thought that the 89 vits would be Dizzy.
If it is coil packs, there should be constant power to the packs when ignition is switched on, it should be the black wire with the white stripe from memory, if the pack isn't firing I would chase the signal wire to the computer and make sure it isn't broken, if your crank angle sensor isn't working I would expect to see no spark at all.
There should be 3 wires on the coil pack connectors, one will be power, one will be ground and one will be signal from the ECU.
Hope that helps and I hope my memory serves!
Vehicle: Suzuki
Post Posted: Mon May 27, 2013 6:39 pm
We sorted it out, ended up being a faulty switch for a aftermarket kill switch
Users browsing this forum: No registered users and 300 guests
