It is currently Sat Aug 01, 2026 8:30 pm
Post Posted: Sat May 25, 2013 7:34 pm
It's probably been brought up but can you put a auto behind a twin cam? And if so whats involved.
also what sort gearing would i need? I have 6.5s and 31s now. Oh and it's for sierra ute.
Cheers Graham
Post Posted: Sat May 25, 2013 7:41 pm
adapter plate for a vitara auto is probably possible...
Post Posted: Sat May 25, 2013 9:13 pm
G13bb auto might work
Post Posted: Sun May 26, 2013 7:33 am
This is 2nd hand info.
I have been informed the GTI ecu runs different signals to g16b/g13bb and makes using the electronic auto very difficult. Maybe wait until JrZook finishes his thread on working out the aw4 input signals etc.
But a 3 speed would work with a lucky 13 adapter, once gearing is addressed.
Post Posted: Sun May 26, 2013 6:55 pm
Ok so vitara 4 speed auto is electronic but not 3speed? And with adaptor plate it will bolt up? Are autos easy enough to get?
Thanks for the input guys
Post Posted: Sun May 26, 2013 6:59 pm
3 speeds seem to be fairly rare ATM, judging by the difficulty some have had tracking one down. 4 speeds are electronic, 3 speeds aren't.
Post Posted: Sun May 26, 2013 7:04 pm
I'm not in a rush so something mite pop up. Are they normally a good box? Just need to figure what the gearing will be like.
Post Posted: Sun May 26, 2013 7:13 pm
They're a GM box and by all accounts not as good as the 4 speed. It's definitely the easier conversion tho
Post Posted: Sun May 26, 2013 7:15 pm
Ok cool thanks mate.
Post Posted: Sun May 26, 2013 7:22 pm
I don't have much experience with the g13b (GTi) but I have a fair amount of experience with the three speed auto and I'm not sure I'd recommend one behind a GTi motor.
The trimatic three speed runs a 2.54:1 first gear and, AFAIK, a 1.8:1 converter ratio. First gear feels quite tall with the trimatic. With the bottom end torque of a 1.6' this isn't a big problem with the less bottom end torque and a steeper power curve in the GTi, I think drivability would be a bit soft.
It might be fin to play with a higher stall speed in the converter, but this could get a bit hit and miss.
By comparison, the AW-4 has a 2.95:1 first gear and a looser converter with more torque multiplication- I think they are 2.2 or 2.4 converter ratio. It's an excellent offroad auto.
Trimatics are strong and reliable- they can get a bit leaky around the TV cable, but its no big deal, and being 100% mechanical/vacuum, they are very simple. They can be rebuilt to take lots of abuse. Get the stall speed right and it will work fine.
I'll add that if you are planning road driving, It can be very hard to gear a trimatic in a Sierra, not a problem off road though, and I don't think your car sees the freeway.
Post Posted: Sun May 26, 2013 7:27 pm
Why doesn't anyone consider the non-elec OD AW4? Everyone gets scared off by the electrical side of things, but doesn't bother to check if the SAME gearbox as fitted to a dozen other cars may be suitable??
Mid 90's Pajero. Serial code 03-72L, is a manually shifted 4speed variant of the AW4. A G16B auto bellhousing will bolt straight up. A simple adaptor needs to be made to run the sierra transfer, and there may be some considerations to be made with respect to flywheel and convertor, but this mayso the case with the G13b.
Post Posted: Sun May 26, 2013 7:30 pm
No arguments there from me Fatzook, I just haven't heard of anyone who has obviously done it.
Steve
Post Posted: Sun May 26, 2013 7:35 pm
Steve
I have no need for it, but given the price of pajero parts of that vintage, I may just buy one to prove the point.
Post Posted: Sun May 26, 2013 7:38 pm
Steve
Didn't know that. I think I will look at that!
Post Posted: Sun May 26, 2013 8:26 pm
Ok some good info. I'm not at all scared of electrics i just no gti management wouldn't play with tcm info. I do 60kms a day on a highway but i need to keep the crawl ratio i have now. I have a well built g13b so it mite have half a chance with the poor first gear ratio? But what sort of rpm on the hwy ? As far as a auto from a pajero v6 model or diesel??
Vehicle: '96 LWB trayback
Post Posted: Sun May 26, 2013 8:29 pm
Theres a thread on Zukwharrie where a bloke details everything needed to do the pajero box swap. Only issue was it comes in 2 variants of input splines so not all of the pajero boxes swap.
I think the code is actually 03-72L, as the "E" signifies electronic shifting and the "L" is for lockup torque converter.
Post Posted: Sun May 26, 2013 8:31 pm
:wink:
Post Posted: Sun May 26, 2013 9:11 pm
Ignore me I'm drinking :D
Post Posted: Mon May 27, 2013 8:42 am
That's awesome info fatzook! Ill definitely look for 1 of the Pajero autos now! The 3 speed vit autos seem impossible to find these days...
Post Posted: Mon May 27, 2013 9:36 am
And as Gwagon outlined, they are less than ideal for a vehicle driven both on, and off-road.
Post Posted: Tue Jul 16, 2013 5:39 pm
Found the following link. Might be useful interested in the 03-72L 4spd auto-box option
http://bbs.zuwharrie.com/content?topic=113393.0
Post Posted: Tue Jul 16, 2013 6:34 pm
That's some good info mate thanks . So that would be the old boxy shape pajero ?
Post Posted: Tue Jul 16, 2013 8:33 pm
NH-NL model (1991-2000) - but check the serial code for confirmation
Users browsing this forum: No registered users and 387 guests
