It is currently Sun Aug 02, 2026 3:59 pm
Post Posted: Tue May 21, 2013 9:40 pm
How do I adapt the shafts of a vitara manual box to a twin hilux transfer ? Is there an adapter kit ?
Post Posted: Tue May 21, 2013 10:07 pm
Probably easier to get a Ring-R adaptor to a toyota 5speed, then a marlin twin transfer kit for the hilux transfers.
Post Posted: Wed May 22, 2013 6:35 am
Hmmm I have the addapter kit for the vit box to my engine I just need to get a hilux transfer case now and try put them together ha :)
Post Posted: Wed May 22, 2013 9:04 am
As Fatzook said, it'll be a lot easier to use a RingR.
G16b> Vitara bellhousing> RingR adapter> Surf W56 gearbox> Hilux transfer> Marlin adapter> 2nd Hilux transfer>
There is a RingR adapter going cheap in the Getting Rid of Stuff section. Look for a post by Kerrod.
Post Posted: Wed May 22, 2013 10:23 am
He has a GTi motor too.
Post Posted: Wed May 22, 2013 11:30 am
Easy.
Gti>lucky 13>G16B bellhousing>Ring-R>W56>hilux transfer>Marlin>Hilux transfer.
Post Posted: Wed May 22, 2013 12:16 pm
Wow thats alot of adaptors haha
Post Posted: Wed May 22, 2013 12:21 pm
Will that be to long for the swb sierra?
Post Posted: Wed May 22, 2013 12:26 pm
With the second transfer. IMO yes.
Post Posted: Wed May 22, 2013 1:26 pm
I'll get some measurements of mine from front pulley to rear output of transfer and compare it to a stocko WT tintop I have.
From memory my setup is only 75mm or so longer than stock.
Post Posted: Wed May 22, 2013 1:28 pm
Only because of the centres rear output though.
Post Posted: Thu May 23, 2013 12:49 pm
I just measured a stock WT tintop... From front of bellhousing to rear output flange of transfer is 1100mm
My setup with an extra transfer and two adapters is 1155mm :D :D :D
I wouldn't say it is too long for a SWB Sierra. The only drama is the lack of offset on the rear output meaning you'd have to run a Vitara or Hilux rear axle assembly.
Post Posted: Fri May 24, 2013 11:45 pm
What about a Vitara doubler to landcruiser Tcase :wink: Richard is based in the UK though.
http://www.facebook.com/RockwattEng
Post Posted: Mon May 27, 2013 12:30 pm
How does this setup work?
Is it a twin transfer or?
Post Posted: Mon May 27, 2013 1:29 pm
It replaces the Vit transfer with a single Landcruiser unit... No idea why you'd want to do that except the possibility of reduction gearing which I'm pretty sure is also available for Vit.
Post Posted: Tue May 28, 2013 6:05 am
Ahh ok hmmm what about twin vit boxes will it be to week ?
Post Posted: Tue May 28, 2013 7:27 am
twin vit boxes will be challenging, and vit low ratio is 1.82 from recollection (so it isnt gospel etc)
high-high = 1:1
high-low = 1.82:1
low-high = 1.82:1
low-low = 3.31
Ass loads of work for low range of 3.31
You would need to cut down the 1st vit box, and weld the aluminium, back up
make an adapter plate, and an adapter or possibly get a new spline cut on the output of the first shaft (so it will fit into the input of the 2nd vit box)
Bit like this, but more work, for less gain
http://bbs.zuwharrie.com/content/topic,46349.0.html
Search is your friend
http://auszookers.com/forum/viewtopic.php?f=37&t=37205
IMO the 4.24:1 xfer gears would be the easier option
http://www.lowrangeoffroad.com/index.php/suzuki/sidekick-tracker-x90/drivetrain/sidekick-tracker-vitara-4-24-1-rockmonster-transfer-case-gears.html
Post Posted: Tue May 28, 2013 9:06 am
The kicker 3 is the go.
Post Posted: Tue May 28, 2013 10:20 am
Would be if they were still making them. Production stopped over 2 years ago.
Post Posted: Tue May 28, 2013 11:44 am
This.
The undertaker is also dead in the water.
Post Posted: Tue May 28, 2013 11:58 am
Its been in the back of my mind lately. Now i know how to do it haha
Post Posted: Wed May 29, 2013 6:01 pm
What about twins to the auto? Could you do twin lux pretty easy because of it being close to the toyota auto?
On a side not I read you can get a commodore v6 to bolt up to th aw4 and toyota auto box with the rodeo 3.2 auto bellhousing
Post Posted: Wed May 29, 2013 7:11 pm
Does it matter whether its auto or manual?
P.S. Got a Vit transfer on the way :D
Users browsing this forum: No registered users and 335 guests
