It is currently Sun Aug 02, 2026 12:28 am
Vehicle: Suzuki
Post Posted: Sat Jun 15, 2013 10:02 am
I have swb vitara and would like to add another guage, I have bought new temp sender but their is 2 in the of them just wondering what the other one is for thanks
Post Posted: Sat Jun 15, 2013 10:12 am
On EFI cars one is for the gauge the other is for the ECU.
On carby cars one is for the gauge the other is a pollution control item.
Vehicle: Suzuki
Post Posted: Sat Jun 15, 2013 11:03 am
Ok thank you mine is carby so theirs no way I can pull the pollution one out and put aftermarket guage sender in it ?
Post Posted: Sat Jun 15, 2013 11:07 am
Do you have extractors on yours? If so then the pollution stuff is doing nothing
Vehicle: Suzuki
Post Posted: Sat Jun 15, 2013 11:08 am
Yes I have extractors so I'll pull it out and put guage in their thanks
Post Posted: Sat Jun 15, 2013 4:49 pm
Vitaras have a temp sender to shut down the aircon pump, and run its fan only, if motor overheats.
It looks the same as a gauge type, but operates differently.
Unsure if carbed Vits have them.
I pulled mine, used it for a 2nd guage.
Wired original override into a switch.
Post Posted: Sun Jun 16, 2013 7:29 am
Unsure if carbed Vits have them. Yes, they do
They sender closer to the firewall is the water temp sensor. The one closer to the radiator is associated with the air conditioner.
I recently-and wrongly-replaced the a/c sender with a water temp sender and found that as soon as I started the car the thermatic fan that cools the a/c condenser came on. :(
I don't know if you can do what you want to do.
Post Posted: Sun Jun 16, 2013 9:00 am
I put a proper temp sender in its place, for my 2nd gauge.
Then I ran the hi temp cut out wire thru an earth switch.
I just throw switch when I want extra radiator cooling without ac.
Down side being if it overheats it wont don't it automatically, I have to do it.
Vehicle: Suzuki
Post Posted: Sun Jun 16, 2013 5:36 pm
Thanks for the replys It has helped heaps
Users browsing this forum: Google [Bot] and 1227 guests
