It is currently Wed Oct 21, 2026 7:29 pm
Post new topic Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3  Next
Post Posted: Fri Jul 24, 2009 1:28 am
Sam, try the pull one bolt trick - it will totally transform the car.
Even if you put rubber bushes in the front, I reckon you'd need a swaybar in the back to get the roll stiffness in the rear to match the front, which is the big downfall of the coiler.
Post Posted: Fri Jul 24, 2009 5:35 am
Or you could pull all the bolts out and see how well it fleximus's then , wont help you solve your problem but it sure would make for some fully sick mate photos :lol:
Vehicle: 07 vvt jimny
Post Posted: Fri Jul 24, 2009 11:47 am
sweet as man :D i have a 85 hardtop "high roof" sierra its green and has sierra sticker up the side :D also have a 07 jimny with federal courgia MT' and some lift :D might see ya round one day mate
Post Posted: Fri Jul 24, 2009 12:18 pm
Hi zuk85, Saam has a Glasshouse Mtns run organised for Saturday, check out the trip thread, hopefully will see you there.
Post Posted: Sat Jul 25, 2009 10:26 pm
ahh was recovering today lol had a boys night out with the mates last night :D:D hopefully the next time i will make it, doing a road trip in the jimny to the snow end of next week for 2 weeks.
Post Posted: Sat Jul 25, 2009 10:40 pm
Cool, snow pics!!!
Post Posted: Sun Jul 26, 2009 4:20 pm
I think it is pretty close now steve, i changed the rubber bushes into it on friday out at my mates block. i was driving over some obsticles and the front was moving alot better, the rear is very stuff because of those poly bushes and was actually surprised with the movement i was getting from the front and how stable it was feeling, ive never really felt the front moving before, i think i could go longer shocks now easily aswell.
the only problem is the softer bushes have highlighted some other issue with the front suspension and i am now getting bone rattling death wobbles which try to throw me into oncoming traffic .... it's really really bad
here are the arms now.
I checked the front wheel bearings and king pins and they have no play at all, the castor angle was compared to a standard coil sierra (spent hours trying to find one lol) and they are exactly the same, so we got the arms right the first time, the toe seems to be right, the panhard bushes are fine so the search continues for the sierras motive to kill me..
i have one leaking front shock but i can't see the causing the wobble to the extent that i am getting it, it really does nearly throw itself off the road, nearly cleaned up a car ! anyways new shocks are on the way but yeah..
Post Posted: Sun Jul 26, 2009 4:25 pm
also other than the death wobble issue, it drives just as nice on road as it did, it's actually much smoother over bumps :)
Post Posted: Sun Jul 26, 2009 4:34 pm
is the wobble there all the time or just at certain speeds?
Post Posted: Sun Jul 26, 2009 4:43 pm
randomly shows up, at all different speeds, corners, shape of the road, speed bumps etc
Post Posted: Sun Jul 26, 2009 4:49 pm
do a front to rear tyre rotation, you may have lost a lead or have a bubble in ya tyre. at the least it will rule out tyre issues.
this bubble made my sierra do some freaky stuff :lol:
Post Posted: Sun Jul 26, 2009 5:05 pm
what am i looking for?
navara on 33s. hopfully rear air locker soon
Post Posted: Sun Jul 26, 2009 5:10 pm
the big bubble on the top right quarter of the tyre.
sam, have you checked your front disks to see if they are warped?
Post Posted: Sun Jul 26, 2009 8:02 pm
I keep reading it, yet i don't seem to ever see these stability issues i keep reading about.
Vehicle: LJ20 LJ50
Post Posted: Sun Jul 26, 2009 8:12 pm
Well not pointing out the obvoius but one of them is a crowbar. Are you using JoshNZ as a technical adviser?
Camels have nice toes
Post Posted: Sun Jul 26, 2009 8:44 pm
lol..
anyways i put a whole set of stocko tyres on it, and no difference just a bit less severe due to less weight...
ans don't think it could be disks because you don't feel it in the brake pedal while it is doing it and ive never had and brake issues
Post Posted: Sun Jul 26, 2009 8:58 pm
worlds wobbliest roller skate
Post Posted: Sun Jul 26, 2009 8:59 pm
so far i am stumped...
Post Posted: Sun Jul 26, 2009 9:07 pm
Steering damper? Rubber bushes damaged? Grasping at straws 'cause I can't think of anything to suggest, Sorry Sam!
Post Posted: Sun Jul 26, 2009 9:19 pm
are your hubs locked? you might have to use ball's method of fault finding.
drive it until something brakes and then fix it. 8)
Post Posted: Sun Jul 26, 2009 9:25 pm
Shot in the dark but try these , have your front brake discs skimmed and have your front wheels balanced.
All tie rod ends, wheel bearings and kingpin knuckles should have no wear or movement.
All suspension bushes must be in good order.
Post Posted: Sun Jul 26, 2009 11:55 pm
hubs aren't locked, they don't have a steering damper and all they do is pretend to hide problems anyways, rubber bushes are fine all bearings and everything are fine. Ive tried two sets of wheels and it's not related to braking and the disks are not warped..
We are re measuring and changing the castor, aiming for between 5.5 and 7 degrees and seeing how it goes, right now it is nowhere near it so we must have stuffed it up when we made the arms, the poly bushes have just been hiding it. Wednesday is the day, the diff brackets are going to be modified. by redrilling / changing the holes we can adjust and test castor settings untill it drives well.
anyone who knows anything about this more info the better :)
sam
Post Posted: Mon Jul 27, 2009 12:17 am
I think that steering damper is a worthwhile addition.
Our totally stock Jimny had bad vibration straight off the showroom floor. Hence nothing to do with worn or modified anything.
My Jimny had the same problem which I had assumed was due to bigger tyres.
Both cars were fixed with the addition of a damper kit.
I don't know why they don't come with dampers straight from the factory.
Post Posted: Mon Jul 27, 2009 12:27 am
yeah dampers do have their place, and i do have one i can put back on, but this is not a vibe or a little wobble, it literally throws your hands off of the wheel and is not safe to drive.. it's serious enough that i am taking my dads car to uni and he had to ride his trail bike to work lol
Post Posted: Mon Jul 27, 2009 12:35 am
I think you are onto it Sam... Caster needs increasing. I believe you need about 7 degrees.
Post Posted: Mon Jul 27, 2009 12:36 am
how does your steering wheel sit when u drive straight or on an angle??
and how long since ur last wheel alignment with the bigger tyres??
our jimny gets severe death wobbles with the bigger wheels if we dont get a wheel alignment every 6 months, just had one done and 2 new front tyres put on and a 60k service, car is running like a dream no wobbles at all it so smooth i almost dont wanna take it on the snow and ruin it ha ha ha ha :D:D but nah i have to play lol :P
howd u go with the flex?
Post Posted: Mon Jul 27, 2009 12:41 am
wheel alignment on a jimny should not change like ifs cars do, there is only a toe adjustment...steering wheel on mine is straight but the only thing that can effect that if your pitman arm is centred when your steering wheel is centred, is the length of the drag link, which i adjusted for the lift...
AND Jas, at the moment it is nowhere near 7 so that's what we are chasing hoping that's the issue.
Post Posted: Mon Jul 27, 2009 12:45 am
its a harmonic based on some random weight and spring of something, the rubber bushes have changed this
until you get the death wobble youll never understand that its not out of balance tyres or wobbly discs or king pings, no shit you will rip the front diff out if you have the strength and room to hold it straight for long enough
damper between the panhard and steering arm, its not a bandaid its dampening a harmonic vibration :wink: thats the only thing that would fix mine
If it is shaking/shimmying/wobbling AND not centreing itself after a turn I guarantee it is a caster issue.
Post Posted: Mon Jul 27, 2009 12:55 am
yep you know the type of death wobble i'm experiencing lol, i'll be fixing the castor because i do normally have a bit of a centering and shimmying sort of issue i just ignore when i had poly bushes. and if that doesn't stop the death wobbles i will stick my damper on the way you have described..
Users browsing this forum: Google [Bot] and 129 guests
