It is currently Tue Nov 03, 2026 8:03 pm
Vehicle: hkbjk
Post Posted: Sun Jul 28, 2013 9:10 pm
Does anyone know off hand what size tube to buy for extending all the case breathers for Diffs etc?
Also would it matter what the tube is? that cheap clear stuff, a bit more heavy duty black rubber one or would you need to worry going to braided or anything? (I don't think you would need to but thought I'd ask)
Post Posted: Sun Jul 28, 2013 9:26 pm
1/2" fuel hose with go on top. But its bulky I reckon.
Adding a 1/4" barb to use 1/4" fuel hose has worked without fail for me.
Vehicle: hkbjk
Post Posted: Sun Jul 28, 2013 9:30 pm
sweet. cheers
i used vacuum hose from memory
Post Posted: Sun Jul 28, 2013 9:37 pm
viewtopic.php?f=14&t=6031&hilit=diff+breather
Post Posted: Sun Jul 28, 2013 9:40 pm
This.
http://www.ebay.com.au/itm/4WD-OFF-ROAD ... 46f&_uhb=1
Post Posted: Sun Jul 28, 2013 9:46 pm
http://www.auszookers.com/forum/viewtop ... t=breather
Vehicle: Suzuki Jimny 2010
Post Posted: Mon Jul 29, 2013 8:31 am
I'd buy the eBay job. They're a good bit of kit :)
Vehicle: '94 suzuki maruti
Post Posted: Mon Jul 29, 2013 6:33 pm
with that, do you need to drill the existing breathers? or is the thread tap right to go straight in?
Post Posted: Mon Jul 29, 2013 7:47 pm
You tap the existing hole slightly just enough to get the connector piece in
Vehicle: hkbjk
Post Posted: Tue Jul 30, 2013 7:40 pm
Yeh I had a look at those, will either run with one of those kits or I had a design in mind to fabricate for a little breather box out of some stainless and a mini filter, am just working out where I want to mount it all.
Where do you all think to mount them? I was going to preferably not do it in the engine bay, I was actually thinking up high near the roof line inside the rear of the car, or having 2 if need be (to cut down the length of hose required) one at front and one at rear.
Would there be any problems mounting it on the inside?
Post Posted: Tue Jul 30, 2013 7:44 pm
Yeah hot oil flying round the cab if u roll
vit rear diff run up behind the tail light into the piller stock
Just put some cheap fuel filters on the firewall
Post Posted: Tue Jul 30, 2013 7:46 pm
if you want them up high, run them up the snorkel
Vehicle: sj51
Post Posted: Tue Jul 30, 2013 8:09 pm
Users browsing this forum: No registered users and 73 guests
