It is currently Wed Nov 04, 2026 2:49 pm
Vehicle: vitara
Post Posted: Thu Jul 25, 2013 6:06 pm
ok, just to update everyone as we had this conversation going back a little while ago.
i put the question out there if 31"muddies would fit on a vitara with a 2" lift kit and nothing more.
i was given about a 50/50 response of yes and no, well,,,, i had a mate come to me a couple weeks
ago and ask if i wanted to buy some 31" maxxis bighorns for $150 for set of 4 with good tread on them
well i'd be stupid to say no, so i did, chucked them on my rims (im still after some sunraysias by the way)
and went for a drive, around town they fit fine after i re-manufactured the front inner guard.
THEN we desided to go for a nice little drive off road..... as soon as you flex abit more then a little your
lovely nobleys deside to get chewed up and spat out by the arches on the rear,,,,
the question is will 31" muddies fit on a Vitara with a 2" lift kit?
the answer is YES but not very well,,,,, lmfao
Post Posted: Thu Jul 25, 2013 7:01 pm
You will need to flatten the lip on the inside of the rear guards that is where the outer and inner guards are spot welded together. I am running 31 inch simex's and with this mod have very little rubbing.
Pete
Post Posted: Thu Jul 25, 2013 7:59 pm
So the answer is the answer we gave you?
Post Posted: Thu Jul 25, 2013 8:08 pm
pretty much pompoms viewtopic.php?f=1&t=41142
you'll need a heap of clearancing & hammer time with 2" & 31's
Vehicle: 1995 2.0V6 Vitara LWB
Post Posted: Sat Jul 27, 2013 2:06 pm
bump stopping is your friend and use longer shocks to get the same flex just with less up travel and more down travel iv seen jeeps running 37"s on a 2" lift it can be done f you plan it out carefully
Vehicle: vitara
Post Posted: Sat Jul 27, 2013 5:56 pm
ok, need a replacement 31" 10.5 r15 maxxis bighorn or cheap set of something else muddy now, i popped the sidewall of one today, was a real drama, i'll tell the story in a new chat shortly, oops
Post Posted: Sat Aug 03, 2013 4:10 pm
Yeah, IFS is a little more complicated than just chucking in longer shocks...
Post Posted: Sun Aug 04, 2013 12:06 am
this is true in the front these things have next to no suspension (nor will they ever) however u can gain the suspension travel in the rear again
Post Posted: Sun Aug 04, 2013 3:26 am
Strut spacers add travel, if you don't already have them or longer struts they are worth the investment.
Post Posted: Sun Aug 04, 2013 9:41 am
how does a strut spacer add travel? the strut still has the same amount of stroke with or with out a strut spacer, they just reposition where that travel sits to get more droop. :?
Vehicle: 93 Vitara -itty bitty lift
Post Posted: Sun Aug 04, 2013 1:02 pm
and you will still need bump stop spacers....
Post Posted: Sun Aug 04, 2013 8:22 pm
Because in the stock configuration the wishbone hits the bump stop with around 2" of travel still left on the strut. Drop the top mount down and you get 2" more droop but the same amount of compression, its just that the shock is now fully compressed when it hits the bump stop.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 68 guests
