It is currently Wed Nov 04, 2026 5:01 am
Vehicle: 95 sj70 and 78 lj81
Post Posted: Mon Apr 08, 2013 8:49 pm
Just wondering what sort of exhaust/muffler/cat to run in the LJ
Do 79 model rules apply or the engine year 93?
Post Posted: Mon Apr 08, 2013 8:51 pm
year of engine in QLD. You'll need a cat.
Muffler choice is up to you, but obviously there are noise restrictions.
Post Posted: Mon Apr 08, 2013 9:02 pm
thats what I heard but didnt want to believe it. What size works well with these engines, if it makes any difference its efi
Post Posted: Mon Apr 08, 2013 9:06 pm
2" press bent will be fine. Fit a chambered muffler, not a straight through one, and you'll be fine.
Post Posted: Sat Aug 03, 2013 5:07 pm
Got all the bits to finish the exhaust this weekend. Is there a desired length from the extractors to the cat or doesnt it matter?
Post Posted: Sat Aug 03, 2013 5:26 pm
The closer the better.
Post Posted: Sat Aug 03, 2013 6:34 pm
I was afraid of that, there's not a lot of room between the LJ rails. I'll see how I go - might be able to jam it up there
Vehicle: Daisy
Post Posted: Sun Aug 04, 2013 2:04 pm
When I built my exhaust the other week out of bits from both the Sierra and the stock exhaust I took from the baleno, I mounted the cat as close as I could get it to the extractors but up between the rails so that it wouldn't rip off, this may even be back behind or level with the transfer. Hopefully it's all good like that otherwise it will get torn off just by looking at it...
Post Posted: Sun Aug 04, 2013 6:32 pm
Well I had slow progression as I said before there is not much room. Is there a smaller cat that I could use other than the vit one?
Post Posted: Mon Aug 05, 2013 7:56 am
Yes, for sure, but they get very pricey
Vehicle: 85 ' Drover
Post Posted: Mon Aug 05, 2013 9:21 am
How big is the one you are trying to fit?
http://www.ebay.com.au/itm/2-High-Hi-Fl ... 3f2690cd30
Unfortuntaely it doesnt give a size, but if those are 2" pipes, then thats quite small overall. and only $110.
Post Posted: Mon Aug 05, 2013 7:55 pm
I just good an answer back about the cat it's 6x3x11 compared with the vit one which is 7 1/2 x 4x13 so this might be the trick
I wonder if the hi flow might be too trick for the 1.6
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 103 guests
