It is currently Wed Nov 04, 2026 4:07 am
Vehicle: Vit swb 95
Post Posted: Mon Aug 05, 2013 1:38 pm
Hey guys,
So a LWB sierra has come up very cheap in my area.
Going to have a look at it this week, from the pictures i have seen, it needs a quite a bit of a tidy up. but doesnt look like theres any noticable dents.
So far this is the information ive been told
-1993
-1L
-4 speed
-198,000kms
- GTI Seats
- Stock lift
- no rust
- Comes with RWC
So... I thought 1993 would have to be a 1.3L not a 1L?
Would this be NT or WT - How would i tell when i see it?
Would are things to look for in the Sierras? Rust in certain areas? engine faults? ect.
Here are the pics i was sent so far.
Vehicle: Vit swb 95
Post Posted: Mon Aug 05, 2013 1:42 pm
....Pics pending....
Vehicle: Vit swb 95
Post Posted: Mon Aug 05, 2013 1:48 pm
Post Posted: Mon Aug 05, 2013 1:57 pm
its a maruti, Indian made suzuki
look in all the corners, you will find rust
Post Posted: Mon Aug 05, 2013 2:00 pm
Being a 1993 it will be a Maruti which could be either a WT or a NT. All Maruti's are 1L. The 1L are apparently quite good to drive as they have lower gearing but I think have a tall first gear.
Rust in the sills, edges of the floor, where the flare mounts to the body and in the corners below the windscreen are common spots. Mine has a small amount of rust in the top of the trans tunnel near the firewall and a small section on the rear floor behind the wheel arch where there is another plate welded to the underside of the body, its rusted between the layers.
If its a WT it will have metal wheel arch flares and the leaf springs will be mounted outside the chassis rather than inline.
EDIT: body looks pretty straight, has the interior/rear tub been painted with tar? this could equal hidden rust, also looks like its been resprayed at some point so be wary of whats hiding underneath
Vehicle: Vit swb 95
Post Posted: Mon Aug 05, 2013 2:30 pm
Cheers for all the info :)
From the info if found, its better the get a NT, then put WT difs on it.
This will be a project, so if i cant find any rust ill be happy.
Dont know if id be keeping the 1L for long, due to i would like to run 33's, 6.5 Gears, 2" lift, and a virtual lift (to keep it lower)
Post Posted: Mon Aug 05, 2013 2:41 pm
Not sure if you can fit the transfer gears in the mariti case as there a little different
Post Posted: Mon Aug 05, 2013 2:50 pm
It doesn't really matter either way if its WT or NT, if NT you will need to find a set of WT diffs.
If its a WT its not a huge amount of work to move the spring mounts under the chassis to get the advantages of the NT spacing in the front.
FYI if you decide to put a 1.3 or a 1.6 in it you will need different chassis mounts for the engine (cut some off a dead sierra chassis). I'm putting a G16b in my 1990 maruti chassis and I'm undecided if I use a set of sierra chassis mounts or mod the vitara ones to make the engine sit lower. The transmission mount is different too but I think you can put 5 speed internals in a 4 speed box, the 1L trans tunnel is also a bit smaller, I've chopped the sides of mine out to fit an auto, for a complete 5 speed I think you can massage it with a hammer.
Post Posted: Mon Aug 05, 2013 2:51 pm
fairly certain a maruti case is a 1L case with switch so gears should fit
Post Posted: Mon Aug 05, 2013 3:13 pm
It's a NT, WT have big metal flares.
Maruti transfers will take transfer gears, they're the light switch type.
1ls are awesome but 6.5s with 33s will have it turning at 4250 RPM at 100. If you go WT diffs the diff ratio will be to low and it will only be doing 3800. You really need 4500+ in a 1l. If you went for 4.625 Vitata diff gears you'd be doing 4780rpm at 100 which is pretty perfect.
The Maruti transmission tunnel is the same is a 1.3l one because they use the "big case" gearbox that you can turn into a 5 speed. It's only earlier 1ls that have the smaller trans tunnel, once 1.3ls came out they used the same. I believe the 1.3l Sierra gearbox bolts in (if you're putting a G motor in, bellhousing pattern is different to the F motors).
Vehicle: Vit swb 95
Post Posted: Mon Aug 05, 2013 3:33 pm
So if i was keeping the 1L with the 1L tranfer case, Then popping 33" tires and WT difs on it. 4.625 gears would be what i would want to pop in the 1L case?
Post Posted: Mon Aug 05, 2013 3:40 pm
no, 4.625s are diff gears.
Vehicle: Vit swb 95
Post Posted: Mon Aug 05, 2013 3:46 pm
Ahh okay...
So is that the best way to run the 33's?
- 6.5's in 1L case and WT difs with 4.625's in?
Post Posted: Mon Aug 05, 2013 3:53 pm
depends what motor you will end up with
if you stay 1 litre then yes.
if you go to g16b i wouldnt want it revving constantly at 4000rpm, 3.7 or 3.9 diffs would be perfect for a g16
Post Posted: Tue Aug 06, 2013 10:47 am
I have a stock geared maruti with 33s an a G16A, , goes very well, dont need first mostly, only when cold or uphill, do want to lower the gearing a tad because of the style of driving she mostly does, but for road use, sweet as, G16 and 33s, not a drama.
Without taking into acc the speedo change with the far bigger tyres, she sits on 100kph up hill and down dale with ease, and when you want its still got plenty of get up and go.
I think they came out with 27" tyres, so that is a 18% upgrade on the gears, easy as.
Vehicle: Vit swb 95
Post Posted: Tue Aug 06, 2013 10:58 am
Well if i get it ill just test it,
Have access to some 33's, 31's and 30s....
So i can see how stock goes, and work it out from there :)
Main thing is the clearing to fit the tires first,
Want it low n fat, but still have good travel
Post Posted: Tue Aug 06, 2013 11:58 am
thats easy, just do the exact opposite of this :lol: :lol:
viewtopic.php?f=4&t=42230
Vehicle: Vit swb 95
Post Posted: Tue Aug 06, 2013 12:09 pm
Oh wow.... Sad stuff.....
Yeah thinking 1/1.5/2" springs, RUF, Virtual lift, NO body lift
Havent had much of a look into it (Spec wise) but the above seems to be the go :)
Users browsing this forum: No registered users and 119 guests
