It is currently Wed Nov 04, 2026 1:19 pm
Vehicle: SJ70 1993
Post Posted: Tue Aug 06, 2013 8:17 am
I believe the 1lt Transfer Cases are 1:1 Ratio in hi?
are there any others that also have a similar gearing?
Post Posted: Tue Aug 06, 2013 8:32 am
1l is 1:1.580 in high. One of the Jimny cases is 1:1 or something around that.
What do you want a 1:1 transfer for?
Post Posted: Tue Aug 06, 2013 8:34 am
vitara has 1:1
most of the toyota boxes
patrol
its a long list
Post Posted: Tue Aug 06, 2013 8:35 am
Practically every transfer case made is 1:1 in high, other than older LT 230 and Suzuki.
What are you trying to achieve?
Vehicle: SJ70 1993
Post Posted: Tue Aug 06, 2013 8:51 am
Just getting all my info before i start something i cant finish.
I want to use my sierra as my camping and weekend warrior.
but i want to achieve a lower reduction for rock crawling with out sacrificing my beach driving as im happy how it is on the beach.
i looked into doing a dual tcase setup and also looking at the 4 speed atlas tcase.
i have a spare stock 1.3 tcase at home i was going to mod to fit in front of my current tcase (4.?:1) where the jack shaft is. moving the stock position of the transfer case back abit to accomadate
so im just getting what info i can to decide what i want to do
(i have left over tax return, figure spend it on the zuki)
Post Posted: Tue Aug 06, 2013 9:37 am
Vit doubler.
Vehicle: SJ70 1993
Post Posted: Tue Aug 06, 2013 10:14 am
well i have a vit gear box/ transfer but its not in the best of shape....
Post Posted: Tue Aug 06, 2013 10:16 am
you are looking at a lot of fab work to do this, for very little gain.
maybe post up the gearing you have now, + tire size and we can make some realistic suggestions
Vehicle: SJ70 1993
Post Posted: Tue Aug 06, 2013 10:33 am
i have 4.?:1 in my transfer case running 32" tyres
high way driving is about 3k rpm sitting on 100kmh (does it easily with the 1.6)
i want to gear down more for rock crawling but i do just as much beach driving and i dont want to sit on 5 in low on the beach for ages just to get to where i need
so just looking for best options
Post Posted: Tue Aug 06, 2013 10:41 am
Gear high range up a bit so you are at, say, 3700rpm on the highway and use high range on the beach.
Post Posted: Tue Aug 06, 2013 10:42 am
if you go from 4.1 transfer to 4.9 gears your only going to gain 200 rpm at 100 in 5th
but you will go from 56 : 1 to 66: 1 in low
5.1:1 transfer gears will be around 250 rpm in high and down to nearly 70:1 in low
6.5 gears will take to you 3500 rpm at 100 in 5th but will give you 87:1 reduction in low
as you can see the high range doesnt really change all that much
Vehicle: SJ70 1993
Post Posted: Tue Aug 06, 2013 10:48 am
i can always try 6.5s and use high on the beach.
Thanks for all your help guys.
Post Posted: Tue Aug 06, 2013 12:41 pm
Assuming you have 3K to spend on a Tcase, why don't you go AW4, trimmed down Vit case and a Sierra case behind that to fix up the highrange gearing...
Wouldn't cost Anywhere near as much as an atlas. Still would be cool to see a zook with one.
Vehicle: SJ70 1993
Post Posted: Tue Aug 06, 2013 12:55 pm
well budget left overs from my return is $3500.
i figure ill consult with Wilso's Customs and get some suspensions mods and just get 6.5s and go from there.
Post Posted: Tue Aug 06, 2013 1:03 pm
Haha wait till I give you the current bill, thanks for giving me every bolt seized or snapped as I tried to remove :lol:
Vehicle: SJ70 1993
Post Posted: Tue Aug 06, 2013 1:04 pm
LMAO what ones? body or in the front end?
Post Posted: Tue Aug 06, 2013 2:17 pm
There's a better case then a atlas but can't remeber what it's called haha
Post Posted: Tue Aug 06, 2013 2:25 pm
i was pretty sure that atlas were the ducks nuts!!
Post Posted: Tue Aug 06, 2013 2:35 pm
*waiting for Gwagen Jr to chime in* :wink:
Post Posted: Tue Aug 06, 2013 2:53 pm
^ :lol:
Just the body mounts.
Post Posted: Tue Aug 06, 2013 3:00 pm
An Atlas recreated out of 300M.
Post Posted: Tue Aug 06, 2013 3:56 pm
Debatable but close. The only real competition in the aftermarket is the STAK case which were experiencing problems with jumping out of gear. However they have just been bought out by TWF and are going to be very comparable to an atlas with more options it seems. Which is an option that the OP may consider but I think you're looking at extreme overkill.
Vehicle: Daisy
Post Posted: Tue Aug 06, 2013 6:45 pm
It's annoying the wasted space in the vitara transfer/gearbox I reckon, I think after talking about it here we decided it was because the auto box is longer so the manual box has a gap full of air at the output end before the transfer case bolts up.
Vehicle: Suzuki Jimny 2010
Post Posted: Tue Aug 06, 2013 8:13 pm
Shoulda seen his face/frustration when it snapped the third time.... :rofl:
Vehicle: SJ70 1993
Post Posted: Wed Aug 07, 2013 5:47 am
hahaha man i get quite angry when i do shit like that. spent 2hrs swaping starters around checking if that were duds.... gave up bought a new one got it in and then snapped the positive off the solenoid
Post Posted: Wed Aug 07, 2013 4:55 pm
A mate was lookin at getting a atlas case in his wrangler and the bloke who's building it said said there's a case that's stronger and lighter... He's told about 10 times.... But I forgot hahaha it's something like a rock monster or something
Post Posted: Wed Aug 07, 2013 5:13 pm
If that was true dont you think the ultra 4 guys would be using them instead of atlas cases
Post Posted: Wed Aug 07, 2013 6:56 pm
The only case I could imagine that would be a lot stronger is a np205 but they are a heavy cast iron case with only a 2:1 low range.I have just fitted an atlas to a vit aw4 and it's definitely overkill and I'm not even sure it would fit between the chassis rails as it doesn't even come close in a sierra.
Users browsing this forum: Andygoodbloke and 117 guests
