It is currently Wed Nov 04, 2026 6:02 am
Vehicle: On the lookout
Post Posted: Sat Oct 13, 2012 10:14 am
Gents,
bit of a basic question, but how do I fill the gearbox oil on the Jim?
Thanks,
Si
Vehicle: 2011 jimny
Post Posted: Sat Oct 13, 2012 10:19 am
filler hole on the passager side of gearbox,above the exhaust
edit http://www.supercheapauto.com.au/online ... escription one of these will make life a dream filling it, also good for diffs 8)
Post Posted: Sat Oct 13, 2012 10:27 am
or squirt a mouthful in at a time via the breather :gross:
Post Posted: Sat Oct 13, 2012 5:07 pm
Super, thanks. How about the transfer?
Post Posted: Sat Oct 13, 2012 5:57 pm
Same same, fill from the highest hole till it over flows then put then put the plug back in.
Post Posted: Sat Oct 13, 2012 6:34 pm
Don't drain them until you undo the filler plugs.
Vehicle: Suzuki Jimny 2010
Post Posted: Sat Oct 13, 2012 7:04 pm
What's the idea behind this?
Post Posted: Sat Oct 13, 2012 7:26 pm
so you know you can get oil back in :wink:
nothing worse than draining the diff & the fill plug being stuck & having to fill the bloody thing thru the breather.
Post Posted: Sat Oct 13, 2012 7:42 pm
That's something that would happen to me too lol
Vehicle: 02 Suzuki Jimny
Post Posted: Sat Oct 13, 2012 8:16 pm
I can vouch for that oil pump from Super Cheap. Near best 30bucks I ever spent.
TF
Vehicle: Jimny 2009
Post Posted: Sat Oct 13, 2012 8:40 pm
Ditto on the supercheap oil pump, makes the job twice as quick with 1/10 the mess.
Hardest part about the oils the gear box filler plug, its in a bitch of a position.
Post Posted: Sun Oct 14, 2012 7:49 am
Mine has been jammed in for about twelve months and I have to fill through the breather, hard to not overfill and causes constant pressure leaks :oops:
Vehicle: 2000 Jimny
Post Posted: Thu Aug 15, 2013 7:53 pm
Sorry for the digging but does anyone know where to get a metric square adaptor from that fits? My 3/8 drive is too loose and will strip if I force it
Post Posted: Fri Aug 16, 2013 12:07 am
eBay, repco, supercheap. Any half decent tool shop.
Post Posted: Fri Aug 16, 2013 12:14 am
http://www.ebay.com.au/itm/TWO-PIECE-8M ... 1e7a070269
http://www.ebay.com.au/itm/Drain-Plug-S ... 2a1481e474
Vehicle: 2000 Jimny
Post Posted: Fri Aug 16, 2013 12:03 pm
I will open my eyes a bit better and have another look. I am guessing they are 10mm?
Post Posted: Fri Aug 16, 2013 12:05 pm
10mm square, they're not as common as sideways suggests
Vehicle: 2000 Jimny
Post Posted: Fri Aug 16, 2013 6:42 pm
Ended up visiting 5 shops and the last one was a specialist. Had to buy a whole kit for $99. So with that done have changed the oil in everything bar the rear diff. The nut is rounded so bad :'( will have to find someone with a welder.
Vehicle: Jimny '09 Manual
Post Posted: Fri Aug 16, 2013 9:02 pm
Yeah they hard to find them square bits.
Post Posted: Mon Aug 19, 2013 8:05 am
Tips on removing a stubborn thread... Spray some WD40 around the thread. Do this multiple times over a period. If its rusted real bad, do this for days. Make sure the tool recess is clean of dirt. If the tool is a tight fit, hammer it into the recess. You can even hammer whilst trying to turn the tool. of course, if its rounded that bad, none of this will help.
Vehicle: 2000 Jimny
Post Posted: Mon Aug 19, 2013 11:30 am
Hmmm does this count? ;)
Does the "F24" mean anything??
Post Posted: Mon Aug 19, 2013 11:40 am
that fill plug is Frucked to the power of 24 8O
Post Posted: Mon Aug 19, 2013 11:43 am
looks like my gearbox filler plug, at least this one is easy to get to
Post Posted: Mon Aug 19, 2013 11:47 am
can you get a pair of vicegrips onto it?
Vehicle: Suzuki jimny, WT sierra, GTR.
Post Posted: Mon Aug 19, 2013 11:54 am
Take to it with a hammer and cold chisel.
Post Posted: Mon Aug 19, 2013 11:55 am
Look at the plug again..
Vehicle: 2000 Jimny
Post Posted: Mon Aug 19, 2013 11:58 am
Beat ya to it Atari! Just after I posted the pic I dug a little deeper in the tool box. Not sure why I didn't think of it earlier. Was still a PITA to undo. Now, where do I get new plugs?? Can head back to what previous owner has done and it is a OCD thing of mine to fix stuff as I see it.
I still cant believe that someone has done this to the plug..... well, all of the plugs
Vehicle: 2000 Jimny
Post Posted: Mon Aug 19, 2013 12:25 pm
$45 for the complete set of drain / filler plugs and gaskets from Suzuki.
Post Posted: Mon Aug 19, 2013 1:14 pm
A bit overpriced but it would take you a bit of work to get a set of second hand ones from a wreck. And thats if THEY are worth getting.
Anyone got a link to an ebay sale of the correct removal tool? Does Trade tools sell them?
Post Posted: Mon Aug 19, 2013 1:21 pm
scroll up a bit more :wink:
Users browsing this forum: No registered users and 184 guests
