It is currently Thu Oct 22, 2026 7:02 pm
Post Posted: Wed Aug 05, 2009 1:52 am
Hey all,
well I'm new here & was wondering what are you opinions welded diffs? The sierra I just brought has one & i'm not sure if I should replace it...
Thanks in advance.
Luke.
85 Holden Drover Soft top stocko.
[quote="losfer"
Vehicle: MY2019 Jimny
Post Posted: Wed Aug 05, 2009 2:00 am
They are great off road, and illegal on road.
They will wear your tyres more quickly and place additional strain on your axles/diff.
They are cheap, effective and reliable.
Post Posted: Wed Aug 05, 2009 2:01 am
Cheers for the prompt reply mate.
[quote="losfer"
Post Posted: Wed Aug 05, 2009 2:42 am
If a welded diff lets go it can/will destroy the whole centre.
If a (mini)spool is fitted the worst that can happen is you snap an axle or possibly strip a crownwheel or pinion.
IMHO mini spool is a much better option than welding and has the benefit of being reversible if you decide to change to an auto or air locker or even go back to standard.
Jas.
Post Posted: Wed Aug 05, 2009 2:58 am
i run a welded rear,its as said great in the bush but crap on road and i dont like to drive it on road with it.It is cheap tho and suited the 4b side of things.
I have broken a couple of them and it has destroyed other gears in the diff centre so as said by jas the mini spool would be the better choice here for all his reasons.I am trying to chase up a spare carrier so i can go the spool route.
matt
Post Posted: Wed Aug 05, 2009 4:15 am
What does a mini spool do?
Post Posted: Wed Aug 05, 2009 4:18 am
locks both axles together without the need for welding.
Post Posted: Wed Aug 05, 2009 4:35 am
Oh.... which means, its a full locker?
Vehicle: 1999 Jimny
Post Posted: Wed Aug 05, 2009 10:33 am
Welded diffs............ Maybe just best I say no comment.
not a locker as such but full time locked.
Post Posted: Wed Aug 05, 2009 2:03 pm
This is what happens when a weldie brakes
Post Posted: Wed Aug 05, 2009 10:03 pm
That's a front though. It's not going to be easy to weld one of them strong enough to be sure it wasn't going to break, and in any case, welded front diffs are a a fair PITA to drive with offroad in my experience.
I've welded quite a few rears and they're pretty reliable - it was the first thing I did to my old 1.0 rear diff.
I now run a mini spool rear and that's all I could ever see going in the back of mine, however, I don't DD, mines a LWB, and runs narrow tyres.
Vehicle: 90 WT ST Locker, Tyres
Post Posted: Thu Aug 06, 2009 12:45 am
its the best budget mod u could ever do
Post Posted: Thu Aug 06, 2009 1:49 am
I've never had a welded diff so I can't speak from experience. That said I think in the long term it would be a reverse economy. You'd wear your tyres in half the time and at $150 or more per tyre $400 for a auto locker seems quite cheap. Also there's the cost of replacement axles etc and the time spent under the vehicle.
If however you have an old beater that you don't spend much time, if any, on road with it would probably suit you perfectly.
Post Posted: Fri Aug 07, 2009 3:07 am
Cheers all, For my First post I'm very happy with the response..
Cheers to a good forum!
Luke.
[quote="losfer"
Post Posted: Fri Aug 07, 2009 1:25 pm
the guys runign an mini spool what was the cost for one of them
Post Posted: Fri Aug 07, 2009 1:49 pm
My mini spool cost US$97
Post Posted: Fri Aug 07, 2009 2:46 pm
That's a pretty big assumption zuknutter. I'm not sure that a welded diff 1/2's tyre life, and I'm not sure an auto locker has exactly the same wear rate on tyres as an open diff.
You're also assuming that a welded diff will break axles and an auto locker won't, and there's "more time spent under the vehicle" as a result. Tell that to the guys who have had auto lockers in and out numerous times trying to get them set up right.
It's clear that you're not a fan of welded diffs, and that's fine, but your assumptions aren't necessarily the case.
PS mini spools are now USD $109 Each + shipping.
Post Posted: Fri Aug 07, 2009 8:34 pm
ARB Air Lockers rock.. :lol: :lol:
Post Posted: Fri Aug 07, 2009 8:46 pm
welded diffs i hate. auto lockers i hate (i've had both). both require the driver to be half decent in tricky on road situations. the 'its just my off road toy' just doesn't cut it, as vehicles have to be on road some part of the time. both will lead to excessive axle wear, tyre wear, driveline wear etc.
and encouraging people to use spools or a welded diff is poor pr.
Vehicle: 75 Cruiser
Post Posted: Fri Aug 07, 2009 8:47 pm
bah, a welded diff is just a air locker, with no switch :lol:
Users browsing this forum: No registered users and 79 guests
