It is currently Mon Nov 02, 2026 10:48 pm
Vehicle: 99 Grand Vitara
Post Posted: Sat Sep 21, 2013 6:57 pm
On the last couple glassy runs I've had really high temps/overheated. Not sure what could have caused it because it didn't use to. Even on the highway home I had to pull over a couple times and let it cool down...
Was thinking that my radiator could be on it's way?
Thinking of putting a 3 core radiator into the GV if I can find one that will fit and also put the AC fan onto a switch so I can turn it on when I'm 4wding.
cheers
http://www.strictly4x4.com.au
Post Posted: Sat Sep 21, 2013 7:07 pm
From memory I have seen lots of pictures of your GV FULL of mud and crap. One would guess its blocked.
Post Posted: Sat Sep 21, 2013 7:23 pm
Yeah me too. But it did it to me on the highway on the way there even :/
Post Posted: Sat Sep 21, 2013 7:25 pm
I rigged my AC fan to a switch.
But haven't needed to use it since replacing my radiator.
Blocked up fins is possible if you mud it.
Don't use high pressure to clean radiator fins, they can get bent flat.
Use normal hose to clean it. Easier to clean if removed.
I carry a weed sprayer hand pump full of water, very handy for when mud gets into radiator.
But I avoid deep mud when possible.
Clutch fan could be on its last legs, too.
Apart from all the normal things to check.
Post Posted: Sun Sep 22, 2013 6:44 am
GV overheating at highway speeds is not going to be fan related - the forward motion of the vehicle provides enough airflow - check for a possible blocked radiator (both air flow and water flow)
Post Posted: Sun Sep 22, 2013 5:23 pm
Pulled the radiator out and gave it a good clean. Bit of mud stuck in behind where the A/C is. Also found a nut in the radiator LOL!
Probably gonna get a new radiator, found this 'heavy duty' one on eBay for $120. It's about 8cm wider than standard and it's guaranteed to fit the GV..
http://www.ebay.com.au/itm/1-Heavy-Duty ... 47b&_uhb=1
Post Posted: Sun Sep 22, 2013 6:18 pm
Bought mine off that seller last year, happy with it so far.
Delivery was quick to Melbourne.
Post Posted: Sun Sep 22, 2013 7:04 pm
Good to hear :)
Did you get a "heavy duty" one? Or just standard?
Post Posted: Sun Sep 22, 2013 7:38 pm
I am only guessing standard.
Appeared to be exactly same thickness.
My ebay record not giving any details now.
Post Posted: Sun Sep 22, 2013 7:58 pm
Doesn't look wider to me.
Post Posted: Mon Sep 23, 2013 1:05 am
The core is wider, if you look at stock ones they look really square compared to that.
Post Posted: Mon Sep 23, 2013 5:58 pm
Just measured the spare one hanging up in the shed and its the same dimensions.
Maybe they used some slightly smaller one at some point.
Post Posted: Mon Sep 23, 2013 6:02 pm
wtf, so you don't have a square radiator? Maybe manuals had a wider one? Hopefully this one will fit...
Post Posted: Mon Sep 23, 2013 6:14 pm
This is what I have
http://www.ebay.com.au/itm/1-Alloy-Radi ... ac4&_uhb=1
Post Posted: Mon Sep 23, 2013 6:30 pm
Looks like you have a Vit one rather than a GV one.
Should be much better with a bigger one.
Hopefully brackometry fits up easily.
Post Posted: Mon Sep 23, 2013 6:39 pm
Yeah the smaller one says for JLX and the GV. I'm hoping it just fits up or at least with not a lot of work..
Should run a bit cooler as well :)
Post Posted: Mon Sep 23, 2013 6:54 pm
Your car had probably been tampered with before you bought it! Youve had engine issues before, most likely dodgy bob mechanics beforehand?
Post Posted: Mon Sep 23, 2013 7:14 pm
Tampered with how? :/ Had the car since like 2004. I have the log book down stairs somewhere. Never bothered to get it filled out since I got my hands on it :twisted:
Do you have the small radiator or the larger one?
Post Posted: Mon Sep 23, 2013 7:18 pm
had the car since 2004, but still on p plates.... you must be a shocking driver? :lol:
Post Posted: Mon Sep 23, 2013 7:25 pm
Yeah cause you can legally drive when you're 9
Post Posted: Mon Sep 23, 2013 7:51 pm
I'll measure mine tomorrow.
Post Posted: Mon Sep 23, 2013 8:25 pm
The radiator in the GV is looking a bit sad. A lot of the fins in it are bent or starting to rot. So the XL7 wreck I bought had one in it so i kept it as a spare for when mine finally lets go.
Post Posted: Mon Sep 23, 2013 9:18 pm
Yeah mine looks sad too... Has a couple nice gouges on the other side 8O I think I will get into the regular cleaning of the radiator after big runs. So much shit gets stuck in the fins and you can't get it out without taking it out.
Post Posted: Mon Sep 23, 2013 9:24 pm
I modified my shroud, making the top half easily removable, so I can clean rad more betterer.
Post Posted: Thu Sep 26, 2013 8:19 am
Well radiator came today..... It doesn't fit..
Can someone please take a couple pics of their radiator mounts with the larger radiator.
Post Posted: Thu Sep 26, 2013 6:51 pm
Just been out and had a look at My GV. (99 manual V6)
It would seem that in the first series of GV (98-00) the Radiators are smaller.... only 540mm wide
The Series 2, and above get the larger Radiator. This may be to compensate for the increase in power.
Not sure if the A/c Condensor is larger as well.
Post Posted: Fri Sep 27, 2013 10:29 pm
Mine's an 01 v6 manual and the radiator is also 540mm wide
Post Posted: Fri Sep 27, 2013 10:35 pm
Dafuq?? Wonder which models have the larger one then ?
Post Posted: Sat Sep 28, 2013 7:29 am
grab the radiator supports from a wide radiator model, then it may be an easy upgrade
Post Posted: Sat Sep 28, 2013 8:50 am
I think the hardest thing is going to be the mounts for the A/C condenser. It sits in front of the rad and is bolted to the same supports.
Users browsing this forum: No registered users and 425 guests
