[ 16 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Sun Oct 06, 2013 1:11 pm |
Gday peoples, my lil girl has developed a terrible high pitched squeel, like a very dry bearing that has siezed.
It does not do it all the time, and when it does, you can get rid of it by going WOT for a bit, few secs.
It will even do it when the engine is off, seriously, had it at the mechanics, it squeeled finally, then turned the engine off, and about 2-3 secs later, again the squeel, from normal high pitch and loud to softer deeper and stop.
WTF is going on, spent all Friday searching, pulled the gearbox out, bearings are only about 500kilomets old, all were perfect, did replace spigot, but that wasnt it.
Sometimes it will squeel, and sometimes it wont.
As best I can describe it, its from the bellhousing area, and sounds all the life like a siezed bearing, its loud, but will stop and no noise ??
Any Ideas ?
alien
Joined: Wed Mar 24, 2010 10:30 pm Posts: 16343 Location: Perth
 Posted: Sun Oct 06, 2013 1:22 pm |
does it do it in neutral as well as in gear? Clutch depressed neutral and gearstick neutral?
SuziBlu
 Posted: Sun Oct 06, 2013 1:28 pm |
Every way mate, in gear, out of gear, driving, stationary, foot on clutch, foot off clutch, but only when it wants too.
Scrawny
Joined: Tue Jan 29, 2008 10:30 pm Posts: 10528 Location: Brissie
 Posted: Sun Oct 06, 2013 2:01 pm |
SuziBlu
 Posted: Sun Oct 06, 2013 2:06 pm |
No not from using a stethacope. The thing that has me beat, I will turn the engine off, it will be off for long enuf to get out of car, pop bonnet and then, up it starts for a few seconds ??
Scrawny
 Posted: Sun Oct 06, 2013 2:20 pm |
Can't be a bearing then. Is it an intake thing? Something that runs on vacuum?
SuziBlu
 Posted: Sun Oct 06, 2013 2:22 pm |
Not that I know of, only bog stock in that regard, only thing that comes from the vac side is the dizzy advance
alien
 Posted: Sun Oct 06, 2013 6:10 pm |
is it the exhaust??? a broken mount or something thats swinging in the breeze?
hooki
Joined: Mon Jul 21, 2008 11:30 pm Posts: 1785 Location: perth, WA
 Posted: Sun Oct 06, 2013 6:31 pm |
something to do with the starter motor?
SuziBlu
 Posted: Sun Oct 06, 2013 6:40 pm |
No, not the starter, an nothing broken, it has me completely baffled.
The only thing that I can offer is that when it starts, foot down and it stops, driving of course.
What has me and the mechanics completely stumped is, that sometimes when you turn the motor off, it will start a few seconds after the engine has shut down, and squeal for a bit, thats really weird.
Scrawny
 Posted: Sun Oct 06, 2013 6:51 pm |
That's what makes me think vacuum related
- WOT = no vacuum - squealing after engine shut off = vacuum slowly releasing
Intake leak maybe? I'm guessing there's no egr now?
SuziBlu
 Posted: Sun Oct 06, 2013 6:59 pm |
Scrawn, we did a run with some start u basted with the engine running ??
That does make sence tho.
No brake booster, only leg power, only thing hooked up ius the dizzy vac advance.
Its dark now, but ill go have a looksy in the morning with that in mind.
Scrawny
 Posted: Sun Oct 06, 2013 7:22 pm |
It's a bit hard to give better ideas without hearing it
SuziBlu
 Posted: Sun Oct 06, 2013 7:39 pm |
Scrawn, its sounds like a seized bearing or bush, high pitched loud scream/squeal, torture. Nothing seized anywhere, or that we could find, 3 of us worked all day on it, mates garage, up on the hoist, down on the ground, then back up, down etc.
My little girl is quite loud, and it is very loud over that.
alien
 Posted: Sun Oct 06, 2013 11:04 pm |
pcv valve maybe? (doubt it but it could be storing pressure up there?)
weelz
Joined: Thu Jun 25, 2009 11:30 pm Posts: 39 Location: Whyalla S.A.
Vehicle: Vitara SV420
 Posted: Mon Oct 07, 2013 10:25 am |
Possibly vacuum in the fuel tank? Do you have a carbon canister under the bonnet? This is the only thing I can see that might cause the squeal when the engine is not running.
[ 16 posts ] |
Users browsing this forum: No registered users and 156 guests
