It is currently Thu Sep 24, 2026 4:06 pm
Vehicle: 99 Grand Vitara
Post Posted: Mon Oct 21, 2013 11:57 am
Pretty sure my rear LHS wheel bearing shit itself on Friday as my wheel started to wobble pretty bad... Tried pulling my LHS axle off but it's proper stuck :/ Thinking my wheel bearing has shit itself and is blocking the axle from coming out. RHS came off piece of piss, 2 pulls.
Last time I pulled it to change diffs it was pretty hard to take off and put back in but this is ever worse.
Any suggestions how to get it out? Mate said maybe heat it up?? Need it fixed asap..
http://www.strictly4x4.com.au
Post Posted: Mon Oct 21, 2013 12:03 pm
What have you tried so far?
Re-fitting the wheel (use the biggest/heaviest one you have) and doing the nuts up just a couple of threads each, then using it as an oversize slide hammer works for me every time.
Post Posted: Mon Oct 21, 2013 12:26 pm
Just got the drum flipped and pull on that. I don't think I'll be able to use the 32s as a slide hammer because the diff is amost on the ground
Tried looking for a slide hammer today but no one has any decent sized ones...
Post Posted: Mon Oct 21, 2013 12:38 pm
Jack the diff up? Make sure it is well supported (axle stands, spare wheel under it just incase etc).
Post Posted: Mon Oct 21, 2013 2:12 pm
Nup didn't work :(
Any other suggestions?? Sucks you can't smack it out
Post Posted: Mon Oct 21, 2013 4:05 pm
You need to try harder ;)
Attach chain to axle. Wrap other end of chain around sledge hammer head and swing it away from the car (again - acts as a mega over-size slide hammer). That said I reckon the 32 is more effective personally, you just need to brace yourself and be particularly violent when pulling to get as much momentum as possible in the 15 odd mm of space you have.
Post Posted: Mon Oct 21, 2013 4:08 pm
what have you tried exactly? :?
Post Posted: Mon Oct 21, 2013 5:15 pm
Using the drum as a slide hammer and the 32" as well.
Post Posted: Tue Oct 22, 2013 3:06 pm
Finally got it off after a lot of bashing....
Wheel bearing shouldn't be like this should it?
Post Posted: Tue Oct 22, 2013 3:08 pm
ahahaha no! :roll:
Post Posted: Tue Oct 22, 2013 3:19 pm
Didn't think so ;) Anyone have a good link for replacing the rear wheel bearings?
Post Posted: Tue Oct 22, 2013 8:09 pm
I know that you have already got it out. just thought I would vouch for the chain technic I have done in the past works a treat I don't have a sledge so it was an axe in my case.
Post Posted: Tue Oct 22, 2013 8:11 pm
yep, quite a few hidden either in good tech or under the search function.
Post Posted: Tue Oct 22, 2013 9:10 pm
Can't find any under either, do you know who the poster is....?
Post Posted: Tue Oct 22, 2013 9:32 pm
Starts with
'S#39'
Post Posted: Wed Oct 23, 2013 12:20 am
The fuck?
Post Posted: Wed Oct 23, 2013 12:49 am
Rhymes with pep
Post Posted: Wed Oct 23, 2013 8:01 am
ahhh so it's the same as sierras as well. Cheers
Users browsing this forum: Google [Bot] and 41 guests
