It is currently Mon Nov 02, 2026 3:24 pm
Vehicle: suzuki sierra
Post Posted: Sat Nov 09, 2013 1:36 pm
is there any bigger radiator fan for a swb 1.3ltre holden drover? the one thats on it now seems to small.
cheers
Post Posted: Sat Nov 09, 2013 3:12 pm
Electric one
Post Posted: Sat Nov 09, 2013 3:52 pm
Bolt in a vitara viscous fan. No modifications are required. It's much bigger than a 1.3 fan, and it's 500% more reliable than an electric fan.
Vehicle: 4wd
Post Posted: Sat Nov 09, 2013 3:59 pm
What gives you that impression?
Watch out or you'll get sued.
Post Posted: Sat Nov 09, 2013 4:02 pm
What Steve said X1000.
Here's a guide on how to refill the oil on one. Might as well do it before you fit it.
viewtopic.php?f=17&t=28644
What makes you think the current fan is to small, is it overheating? Edit, beaten.
Post Posted: Sat Nov 09, 2013 4:56 pm
.....and it's 500% more reliable than an electric fan.
Never said the electric ones were any good. He gave us a vague question so I gave him a vague answer
Post Posted: Sat Nov 09, 2013 5:56 pm
thanks fellas. and yeah it sits just below the "h" line
Post Posted: Sat Nov 09, 2013 6:05 pm
is this the one you were talking about steve?
http://www.ebay.com.au/itm/Suzuki-Vitar ... ad4&_uhb=1
Post Posted: Sat Nov 09, 2013 6:36 pm
Yes, but you need the viscous hub that goes in the middle too.
Post Posted: Sat Nov 09, 2013 6:40 pm
Here are some comparison photos.
From left, a 1.0 fan, a vitara fan and a 660cc sierra fan, which is basically the same as a 1.3 fan.
And a 660cc/1.3 fan laid over the vitara fan.
And the vitara fan in the car. It's a really tight fit inside the 1.3 shroud, which is awesome for the efficiency of the fan. This was my car running a 660, but it doesn't matter. Fan location and radiator is the same. I swapped from this to a magna thermo which was the same size due to water pump problems and my car overheated. Electric fans bring the suck.
Get one from a wrecker. I think you can get knockoffs from Ebay, but as they are non genuine, who knows?
I don't know anybody that has fitted one of these that has subsequently had ANY problem with overheating.
It's what I would run if I still had the radiator in the front of my car.
Post Posted: Sat Nov 09, 2013 7:45 pm
Id be looking at some thing else thats giving you the overheating issues. Stock fan should work fine.
Post Posted: Sat Nov 09, 2013 8:22 pm
I disagree. I recall a club member with a stock sierra that was fresh off the showroom floor overheating in 1996. They don't overheat with a vitara fan.
Steve
Vehicle: 1985 SJ51T
Post Posted: Sun Nov 10, 2013 2:53 pm
Make sure the stock fan is bolted on the right way. I made that mistake lol
Post Posted: Tue Nov 12, 2013 5:26 am
I have a Vit Viscous engine fan and a 10" thermo on the front that i turn on when crawling.
Post Posted: Wed Nov 13, 2013 6:50 pm
might be 500% more reliable than a electric fan , but its still less reliable than a direct drive fan that they come with stock.
Users browsing this forum: No registered users and 91 guests
