It is currently Sun Nov 01, 2026 4:30 am
Post Posted: Fri Nov 15, 2013 4:54 pm
Has any one came across this problem were g16b hits the brake hard lines coming out of the brake cylinder. Running a 2 body lift. Body still has to go towards passenger side 10mm.
Post Posted: Fri Nov 15, 2013 5:02 pm
What engine mounts are you using? Commonwhore?
Post Posted: Fri Nov 15, 2013 5:09 pm
Looks like stock on ps and benT on ds. Engine was pulled from another sierra
Vehicle: 4wd
Post Posted: Fri Nov 15, 2013 5:55 pm
I had to adjust the hardline when doing my g13bb conversion, but don't recall having to do it with my Baleno g16b conversion (slightly taller motor).
Watch out or you'll get sued.
Vehicle: 91 WT 1.6EFI
Post Posted: Fri Nov 15, 2013 6:48 pm
I have the same setup and mine doesn't hit. There is some trickery going on somewhere, I'll check mine out in the morning.
Vehicle: 89 Sierra Widetrack
Post Posted: Sat Nov 16, 2013 8:10 am
I have plenty of space on mine I'll check again when I get home
Vehicle: 85 SJ413
Post Posted: Sat Nov 16, 2013 11:03 am
Check that the cast engine mount brackets that bolt to the block are from the 1300. The 1600 ones are a different height and might be causing the engine to lean over.
Ben
Post Posted: Sun Nov 17, 2013 3:27 pm
Here is a pic of mine not sure why yours is so close
Post Posted: Sun Nov 17, 2013 4:10 pm
Yours is from a baleno right? My g16b is from a vitara. Might be different. You running body lift at all?
Post Posted: Mon Nov 18, 2013 8:26 am
Yes my G16b is from a Baleno
Users browsing this forum: No registered users and 671 guests
