It is currently Sat Oct 31, 2026 12:31 pm
Vehicle: 92 sierra tintop, 88 WT sj50
Post Posted: Mon Nov 18, 2013 9:39 am
Hey guys. Im putting some nt 3.9 centres into my wt sierra. I want to try and keep wt diff flanges as they have larger bolts. But the splines are different 3.7 wt to 3.9 nt. Do you guys know if any other suzuki flanges will work with the nt splines but be a wt bolt - vitara/jimny eg??
cheers guys
Post Posted: Mon Nov 18, 2013 10:07 am
just drill the bolt holes out?
Post Posted: Mon Nov 18, 2013 10:16 am
Splines are all the same WT to NT afaik.
Post Posted: Mon Nov 18, 2013 10:19 am
My 3.9s that I have are out of a drover. Will that differ?
Post Posted: Mon Nov 18, 2013 10:21 am
there are some differing splines but ive never found an order to the chaos.
I.e ive had vitara flanges that wouldnt fit WT gears, NT that fitted WT perfectly.
Post Posted: Mon Nov 18, 2013 11:44 am
I cant drill either because theres not enough meat on the nt flange. The actual outer diameter is smaller than the wt flange
Post Posted: Mon Nov 18, 2013 11:50 am
its just gonna be a case of trying some other flanges until you find some that fit.
Be aware though that you really need to replace the collapsable spacer in the diffs if you undo the pinion nut.
Post Posted: Mon Nov 18, 2013 11:54 am
I might just change the flange on my tailshaft from the uni to nt. Not what I wanted to do due to smaller bolts but looks to be easiest way out
Post Posted: Tue Nov 19, 2013 6:07 am
x2 ive had varying success with no consistency.
Post Posted: Tue Nov 19, 2013 8:07 am
Sj80s have a different spline cut
Post Posted: Tue Nov 19, 2013 8:19 am
why doesnt that surprise me
Post Posted: Tue Nov 19, 2013 10:03 pm
Haha que nothing fits a coily
Users browsing this forum: Google [Bot] and 110 guests
