It is currently Mon Nov 02, 2026 11:45 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
Post Posted: Mon Sep 03, 2012 5:47 pm
zukmeista wrote:
Read The FACTORY Manual.
Correct, while "Read The F****d Manual" is a reference to the Haynes one.
Suzuki Factory Manuals are far superior to any of the aftermaket published ones for techinal information and step-by-step readability. They rarely leave anything out, which Haynes and Gregory's are notorious for. Best of all, the Factory ones for most Suzuki vehicles are available online or CD, where you usually have to shell out cash for a Haynes.
The Full Sierra one can be found via http://www.4x4.in.th/manual_sj413/chapter0.pdf for the menu, then just replace the required chapter number in the address. Just about all the other Suzuki ones can be found on Suzukiinfo or LJ10.com.
Post Posted: Tue Sep 04, 2012 10:06 pm
So who uses a solid spacer? Is it just a bit of crap built by the diff guy, or is it the most important part of any diff rebuild?
Vehicle: '92 Sierra
Post Posted: Wed Sep 05, 2012 7:21 am
I don't think the F stands for factory hehe.
Post Posted: Sat Nov 16, 2013 8:37 am
I have to do the same job on my 89 sierra, any pointers for a stubburn pinion bolt. mine wouldnt come off with a 1/2 inch rattle gun
Post Posted: Tue Nov 19, 2013 12:37 pm
Well, I was having allot of trouble. My trade tools budget line air impact 1/2 inch gun couldn't do it. However, a mate brought his Ingersoll Rand air impact gun over, and it was like slicing though butter.
http://www.ebay.com.au/itm/Ingersoll-Ra ... 53ee653109
Post Posted: Tue Nov 19, 2013 4:53 pm
I have a cordless ryobi impact wrench that has no problem undoing pinion flange bolts, especially in places like the you pull it wreckers and cheaper than that ingersol rand impact wrench
Post Posted: Tue Nov 19, 2013 6:23 pm
ok the 3/4 rattle gun failed. I did get it off in the end using a 3/4 breaker bar and driving the car forward. now i have a new problem.... getting the flange off
Vehicle: Sierra
Post Posted: Sat Nov 23, 2013 8:23 am
undoing the pinion nut will be easy compared to crushing the crush sleeve if you replaced it with a new one. You will want a good breaker bar with a pipe over the end to get more leverage. Apperently it usually takes around 400 ft-lbs to start crushing the sleeve.
Users browsing this forum: No registered users and 130 guests
