Vehicle: 92 Sierra
Posted: Thu Nov 21, 2013 4:53 pm
Theres 1 kit on eBay poly bushes - $179 n suzistore has a kit rubber for 99, is there anywhere I can get a replacement kit cheaper? I need to pull out my 2" lift kit for a roadworthy. cheers.
^^^ What he said, rubber sheet or conveyor belting.
Conveyor belting is lots easier to cut if you bend it so your stanley blade isnt trapped by the rubber. Dont try to cut all the way through in one go, take a few swipes- then there is much less force needed + less chance of your thumb ending up on the "I'm a dickhead" or the "pain thread"
Dribble water on the belting while you cut the straight bits, water makes the blade cut lots easier,
Then a hole punch, water and big hammer for the bolt holes. [drill can be used- but it will probably try and grab and spin]
Users browsing this forum: Google [Bot] and 42 guests
