It is currently Sat Oct 31, 2026 5:36 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
Vehicle: SJ80
Post Posted: Thu Nov 21, 2013 9:13 pm
quick question.... does the tacho need to be wired in for it to run :P because I didn't even think about it but about 99% sure its not connected!!!
Post Posted: Thu Nov 21, 2013 10:20 pm
Jrzook, it's the one I was going to put in my LWB
Ah sweet so its a known good runner.
Considering the wiring issue you had with the coil/ignitor are you 100% sure that everything else is sweet?
Vehicle: SJ80
Post Posted: Thu Nov 21, 2013 10:56 pm
There wasn't a problem in that wiring, it was where I had tapped into the ignition circuit to power the ECM.. just picked up off a circuit that didn't hold 12v while cranking :/ and I was waiting on a copy from killa kustom kables, of the wiring instructions so I can double check them (which I now have)... but there is essentially only 3 wires I had to solder in to the ignition (from a supplied loom that went through a fuse block and into a plug in the vitara harness) with an additional 3 wires for CEL, tacho and VSS if I want to wire them in I suppose. And yes, I did manage to get 1 wire wrong, as I misread the instruction on start signal/or didn't check it properly when cranking. but all sorted now... I think.
Vehicle: 4wd
Post Posted: Fri Nov 22, 2013 5:38 am
I'd be getting the pin out and checking the whole loom.
Another bloke posted this week and is also having problems with his kills kustoms loom.
Watch out or you'll get sued.
Vehicle: SJ80
Post Posted: Mon Nov 25, 2013 6:29 pm
Just want to thank everyone for all the helpful info I received from you all in regards to this starting issue.... Finally sorted it out, and I am potentially a RETARD! after going through everything (seemingly) and losing my shit several times I decided to double check CEL codes the correct way, after cranking for 15 seconds (thanks Rhinoman)... low and behold 12 - everything is fine and dandy. So I had an epiphany - the only thing I didn't look at way my cone type AFM (which is sitting on the ground, plugged in but not working as an AFM now is it??) So I tried cranking whilst in neutral position.... start... sputter.... stop. Try cranking in fully open position... WOOP WOOP SHE RUNS and i'm a retard! the one thing I hadn't checked in almost the entire circuit :/ so once again, thanks for putting up with the retarded questions and pointing me in the right direction! I now have a much better understanding of the inputs/outputs to the ECMs and sensors/circuits and hope I can help others when the time comes :D
Shadow
Users browsing this forum: Google [Bot] and 386 guests
