It is currently Sat Aug 01, 2026 11:35 am
Vehicle: 92 Sierra hardtop
Post Posted: Sun Dec 08, 2013 3:20 pm
Hey guys newbie here, ive looked around but haven't found a direct answer, will a liana 1.8 non vvt bolt into a 99jimny non vvt. The engine is already out of the car, that I want to buy. But has air con pump, power steer pump, and air intake manifold. And all the wiring for the 1.3, just wondering what else is needed, if conversion is clean swap.... Does it have to be engineered in nsw.
Thanks a lot guys.. Any help would be greatly appreciated,
Vehicle: Suzuki Jimny 2010
Post Posted: Sun Dec 08, 2013 7:55 pm
It'll fit, however you'll need the gearbox and maybe the transfer from an m series, and I think the loom from the liana???
I'm pretty sure there's a thread in the good tech section where someone recently converted a g series to m series... That'll be a good starting point for all your major needs... Then look at the m-series conversion thread for all your minor mods for the job
Post Posted: Sun Dec 08, 2013 8:00 pm
viewtopic.php?t=43068
Here's the g to m swap
viewtopic.php?t=30308
And here's the m series thread :)
Happy reading
Post Posted: Mon Dec 09, 2013 6:05 am
Ok thanks, I'm having trouble understanding engine numbers though, is it g13bb from 88-00, and then from there on m13a,
Cause on eBay, there's and m13a engine out of a 99 jimny, so what's the go with that?
Post Posted: Mon Dec 09, 2013 7:09 am
98-99 G13BB
2000-05 M13A NON VVT
06-Current M13A VVT
G series use a different box and transfer
M Series use the same box but different ratios for non VVT and VVT and I'm pretty sure only the VVT models have push button transfers.
The non VVT gearbox is the one you want if you want to do the sierra transfer upgrade ;)
Post Posted: Mon Dec 09, 2013 7:24 am
Ok thanks mate :D
Post Posted: Mon Dec 09, 2013 8:01 am
jimny_timmy wrote:
98-99 G13BB
06-Current M13A VVT
06-Current M13AA VVT
Post Posted: Mon Dec 09, 2013 8:06 am
Ok wait so is it just a mistake that the wreckers made, saying its a m13a for a 99?? :)
Post Posted: Mon Dec 09, 2013 8:10 am
http://www.ebay.com.au/itm/98-99-00-01- ... 760&_uhb=1
http://www.ebay.com.au/itm/Motor-engine ... d16&_uhb=1
Post Posted: Mon Dec 09, 2013 8:12 am
My main concern with a G to M(VVT) swap is ECU. The G ECU would not know about some of the sensors, or the signals would be different, and a Liana ECU doers not know about 4WD.
Post Posted: Mon Dec 09, 2013 8:18 am
Abouwer123 wrote:
http://www.ebay.com.au/itm/98-99-00-01-SUZUKI-JIMNY-ENGINE-1-3-M13A-DOHC-11-00-/190673921888?pt=AU_Car_Parts_Accessories&hash=item2c650d2760&_uhb=1
Notice the engine mount on the front and the air box on the top. That's not out of a Jimny. Don't know what.
http://www.ebay.com.au/itm/Motor-engine-Suzuki-Jimny-1999-1-3-M13a-/251256278294?pt=AU_Car_Parts_Accessories&hash=item3a800a8d16&_uhb=1
Both definitely M Series, but something is amiss with the years.
Post Posted: Mon Dec 09, 2013 8:23 am
Would it be any different if they weren't vvt which they are not. :)
Post Posted: Mon Dec 09, 2013 8:29 am
There is no way a G series ecu will run an M.
Post Posted: Mon Dec 09, 2013 8:38 am
Ok thanks Steve, so would I have to change the loom as well as the ecu. Would it be easier fitting the 1.6 from a vitara, is that a g16bb or something,
Andre
Post Posted: Mon Dec 09, 2013 8:40 am
Yep the 1.6 is way easier. Ben-t makes the adapter for the conversion I'm pretty sure
Post Posted: Mon Dec 09, 2013 8:47 am
Ok, do you know anyone on here that's done it, is it straight bolt up (with the adapter )and will it work with the 1.3 loom and ecu
Users browsing this forum: No registered users and 251 guests
