| Author |
Message |
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13015 Location: Melbourne
 Posted: Sun Oct 07, 2012 7:48 am |
It's the spindle width that makes the vitara hubs preferable IMHO, in order to prevent having to cut the axlehousing, and make the conversion a bolt on.
kenn
Joined: Tue Nov 11, 2008 10:30 pm Posts: 1202 Location: Melbourne
 Posted: Sun Oct 07, 2012 8:10 am |
I love the way you all guess at why Mr Joe does stuff. I'll let you in on a little secret , he's a freak and he thinks way out side of the box that some of you are stuck in. You've sowed the seed, now just feed it when it needs it and watch it grow.
DarkHorse
 Posted: Sun Oct 07, 2012 3:35 pm |
Most of us struggle to be that patient Kenn
joeblow
Joined: Sat May 10, 2008 11:30 pm Posts: 3273 Location: melbourne
 Posted: Thu Oct 18, 2012 6:01 pm |
Darkhorse the Vit stuff will be a bolt on with what you have now.
Jimny rear track will increase 10mm per side.If Jimny owners are interested please let me know by tomorrow night as I will be placing an order for axle steel next week.
I will take orders from Vit owners but will need some dimensions.
303zuke
 Posted: Fri Oct 19, 2012 7:39 pm |
joeblow wrote: If Jimny owners are interested please let me know by tomorrow night as I will be placing an order for axle steel next week.
Absolutely interested in a kit, but there has been no mention in this thread of cost. For me to commit, you need to give us an approximate price range. I recall your Sierra FFA kits were somewhere around $700, was that right? Will that be the same for these?
zukenutter
Joined: Sun Feb 08, 2009 10:30 pm Posts: 9045 Location: Brisneyland
 Posted: Mon Oct 22, 2012 12:28 pm |
I'm keen to see some of these go ahead, will be a great upgrade. Did you get many orders?
_________________ Click WWW below for STICKERS
31zook
Joined: Tue Mar 24, 2009 10:30 pm Posts: 9242 Location: maito
 Posted: Mon Oct 22, 2012 4:43 pm |
I PM'd him saying I was keen. Dunno if anyone else did tho...
zukenutter
 Posted: Mon Oct 22, 2012 5:50 pm |
31zook wrote: I PM'd him saying I was keen. Dunno if anyone else did tho... WIll he still go ahead if it's just you? Make sure you take heaps of pics when you install.
31zook
 Posted: Wed Oct 24, 2012 4:45 am |
No idea Paul, but if I get it I'll do a full write up. Cheers
Bugsta
Joined: Fri Oct 30, 2009 10:30 pm Posts: 1754 Location: North Brisbane
 Posted: Thu Aug 01, 2013 4:56 pm |
31zook wrote: No idea Paul, but if I get it I'll do a full write up. Cheers  Did you take pics and do a write up on this ? Did you get installation instructions list from Joe? I have not been able to get hold of him. I am just about ready to go. Just waiting on BenT's adapter kit which he posted today.
g r e e n
Vehicle: Suzuki Jimny Sierra
 Posted: Fri Nov 01, 2013 9:34 am |
Hi. We make full floater KITs for Suzuki Jimny. Photos under illustrate process of installation. This mount plate was made for Suzuki Vitara 3d front caliper. Attachment: IMGP7036_0.jpg Attachment: IMGP7042.jpg Attachment: IMGP7044.jpg Later we started to use Golf IV rear calipers with emergency brake. Attachment: 20130717_165911.jpg Attachment: 20130717_165921.jpg Attachment: 20131003_110550.jpg
kenn
 Posted: Mon Nov 04, 2013 6:03 am |
Engineers over here in Aus don't like brake components being welded together. Because of the forces involved, you are relying on a weld to stop your car.
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Mon Nov 04, 2013 9:00 am |
tanshi
 Posted: Mon Nov 04, 2013 9:05 am |
Isnt it exactly the same thing as a line lock in that case?
Gwagensteve
 Posted: Mon Nov 04, 2013 9:23 am |
Yes and no engineer will pass it.
Stock rear calipers don't use a hydro hand brake, they use a mechanical actuator, usually inside the piston.
g r e e n
 Posted: Mon Nov 04, 2013 10:15 am |
On the last pic you can see solid mounting plates.
g r e e n
 Posted: Mon Nov 04, 2013 10:26 am |
tanshi wrote: Isnt it exactly the same thing as a line lock in that case? Of course no. Caliper has little lever. When you pull it piston is pushing out mechanically. Attachment: 20130717_135252.jpg Attachment: 20130717_135301.jpg
jonno_racing
 Posted: Mon Nov 04, 2013 11:06 am |
Thought that may be the case. The popularity of drifting has made them cheap and easy to get. However I have noticed a few newer cars have a single button to press for a handbrake? Not sure on the mechinisim tho. I'm looking into options as I want rear disco on my transfer and hate cables
_________________ Do cool stuff, Put it on the internet Sierra build, Jimny build https://www.youtube.com/user/redzook1
Gwagensteve
 Posted: Mon Nov 04, 2013 11:23 am |
Pushbutton handbrakes still use a mechanical mechanism to hold brake force - there's a geared motor or similar that cranks the cable on to apply the brake. The previous generation 7 series BMW was the first car in Australia with one, and it required a rewrite of the ADR's to allow it to be sold.
In any case, hydraulic pressure isn't permitted to be used as the vehicles handbrake. It must be a mechanical system.
There is also some variation engineer to engineer in Vic over modifications to a hand brake at all. We've had the spidertrax disc transfer brake knocked back by one engineer but fine for another.
Bugsta
 Posted: Mon Dec 23, 2013 10:27 am |
Been fitting my conversion kit this week. FFA, Axle upgrade and Disc Brake conversion all in one. I have come across a potential issue. The axle sits low in the spindle hole. This is not just gravity. Lifting it up moves barely 1 millimeter. Its out by at least a couple. I have rotated the spindles, the adapter plates, swapped sides, and the space remains the same. It suggests to me that the axle housing has been bent an both ends, by way of vehicle weight pushing down and wheels pushing up. What can be done to rectify this?  [/URL]
31zook
 Posted: Mon Dec 23, 2013 11:03 am |
Bent housing. Mine is straight and centered.
SierraDan
Joined: Fri Feb 04, 2011 10:55 pm Posts: 9348 Location: Newcastle
 Posted: Mon Dec 23, 2013 11:09 am |
Your avatar is a clear indication of the problem  Get it straightened if possible or new housing.
_________________ mlm
Mike57
Joined: Fri Jul 22, 2011 11:09 am Posts: 1009 Location: Melbourne
Vehicle: Suzuki Jimny 2009
 Posted: Mon Dec 23, 2013 2:36 pm |
Does anyone know if Joeblow is still producing these? I have sent him a PM to find out. 31zook did you ever do a write up on your installation?
kenn
 Posted: Mon Dec 23, 2013 7:19 pm |
Yes he will be making these again.
henno
Joined: Tue Jul 23, 2013 5:56 pm Posts: 2439 Location: Brisbane
Vehicle: Which one?
 Posted: Mon Dec 23, 2013 7:25 pm |
kenn wrote: Yes he will be making these again. Along with GV front bars, right? RIGHT?
kenn
 Posted: Tue Dec 24, 2013 7:19 am |
All the bars will be done by Uneek now, which will make them more readily available. Joe was showing me the new tweaks he's done to the suzuki bars, they look better again and will be even easier to fit.
31zook
 Posted: Wed Dec 25, 2013 8:08 am |
Mike57 wrote: Does anyone know if Joeblow is still producing these? I have sent him a PM to find out. 31zook did you ever do a write up on your installation? I didn't do one as I was doing it because I was trialing allot of different parts as a test run for it all working. But, with a few hours thinking in the shed it can only go together one way and is simple enough.
Mike57
 Posted: Wed Dec 25, 2013 9:14 am |
Thanks 31Zook. I also read your build thread and noted the modification to the handbrake cable. I think your was pre-ABS right?
31zook
 Posted: Wed Dec 25, 2013 12:36 pm |
Mike57 wrote: Thanks 31Zook. I also read your build thread and noted the modification to the handbrake cable. I think your was pre-ABS right? Yeah, in my build thread I explained how to fix the handbrake cable situation. And after talking with JB for a while, im pretty sure a jimny front hub/spindle will bolt into the same holes and will accommodate for ABS. But this is purely theoretical and we are not 100% sure till someone does it.
zukenutter
 Posted: Thu Dec 26, 2013 8:20 am |
Bugsta wrote: What can be done to rectify this? Change your driving style  lol SierraDan wrote: Your avatar is a clear indication of the problem  Get it straightened if possible or new housing. Lol I have a rear housing for sale
