It is currently Fri Jul 24, 2026 10:13 am
Post Posted: Mon Aug 17, 2009 12:59 am
i put a 1.3L motor into my 1l lwb zook and i got 1.3l diff sitting there i still got 1l tcase and diff in it so what i wont to no what would be better the 1l or 1.3l diff i can sit on 90k but i trying to get 100k every one conplanes that i am slow and the motor seams to be working to much i think the 1.3l diff would be better but would 5th gear be unusable any thoughts are welcome
Post Posted: Mon Aug 17, 2009 1:12 am
WOW take a breath. I don't think that 1.3L diffs fit in 1L housings. BUT as the 1.3 motor was ontop of a NT it will fit. The 1.3NT diffs might just be 4pinion fronts :D
Gear Calc: http://www.izook.com/gearcalc.htm
All the Ratios: www.lepayne.com/gears.html
Post Posted: Mon Aug 17, 2009 1:20 am
i was just going to take everything and swop not just the diff it if that makes sents
Post Posted: Mon Aug 17, 2009 1:43 am
is it a NT or WT 1.3? no matter which one it is the 1.3L diffs will give you better gearing for on road but they will dehance offroad gearing
Vehicle: LJ20 LJ50
Post Posted: Mon Aug 17, 2009 2:08 am
1 litre and NT diffs are the same width and same mounts. WT diffs are different mounts and widths.
So yes they are a bolt in job. can be done very easily.
Camels have nice toes
Post Posted: Mon Aug 17, 2009 2:27 am
i no it would be easy i was thing more in the way of gearing
Post Posted: Mon Aug 17, 2009 2:30 pm
What size tyres do you run on it?
1 litre diffs are 4.1:1, the NT diffs are 3.9:1. If your tyres aren't too big (eg approx. 30") your 1.3 should have the torque to push it along at 100kph. I would think that with a 1 litre transfer case a 1.3 should be able to push 31s at 100kph if the motor is in decent condition.
Is the problem that you cant do more than 90kph currently? If that's the case I think your engine might be sick.
Post Posted: Mon Aug 17, 2009 4:16 pm
i running 30x9.5R15 cooper stt i can do 100kph but i think its called (over run) or something likt that that motor it in good now the gear box is missing 2 teeth but it get me around i got to fix that soon but i dont think thats the problem
Post Posted: Mon Aug 17, 2009 4:59 pm
is it just me or is that hard to read....
Post Posted: Mon Aug 17, 2009 5:07 pm
suzukilwb wrote:
...but i dont think thats the problem
OK, so can you explain a little better what the actual problem is?
If you could structure your answer in proper sentences so I can understand WTF you're actually saying that would be great too.
Post Posted: Mon Aug 17, 2009 5:17 pm
ok i will try the motor over runs trying to do 100kph so i trying to work out what would be better the 1 litre diffs at 4.1:1, or the 1.3L NT diffs at 3.9:1 what would be better on off road
Post Posted: Mon Aug 17, 2009 5:30 pm
by over runs do you mean over revs?
if its over revving you need to get higher gears, the 3.9s are higher than the 4.1s.
the 3.9s should still be low enough for off road use with 30s
Post Posted: Mon Aug 17, 2009 5:33 pm
when you say you motor "over runs" trying to do 90-100kph
do you mean reving hard?
eg 6000 RPM at 100kph, it's a suzuki they're built to rev!
Post Posted: Mon Aug 17, 2009 5:44 pm
over run thats what chris he a mechanic and say it doing it sit on about 3300rpm90kph 3500rpm doing 100kph but the motor sound like its struggling on flat road if that makes sense
Post Posted: Mon Aug 17, 2009 5:51 pm
its not revving overly high in fifth for 100km/h the 4.1 would raise your revs a little but make your highway speed easier on the engine. the 1 litre diffs however are a fair bit weaker when you get them off road i believe.
Post Posted: Mon Aug 17, 2009 11:19 pm
i think i might put it 1.3L diff in and see what it like
Users browsing this forum: No registered users and 351 guests
