| Author |
Message |
gregwatkins75
Joined: Mon Oct 25, 2010 12:13 pm Posts: 1334 Location: WeSt RaDeLaIdE
Vehicle: Suzukiless these days..
 Posted: Mon Feb 10, 2014 7:54 pm |
Have finished swapping the front hubs/ wheel bearings over yesterday.. bought new hub assemblies! plan was to keep old hubs and put new bearings in them as a spare set, looks like the bearings are built into the hub?
It this correct or am I going blind? Can you replace the bearings in the hubs?
royce
 Posted: Mon Feb 10, 2014 8:08 pm |
circlip on the back side, press the lot out in one piece
gregwatkins75
 Posted: Mon Feb 10, 2014 8:14 pm |
Big nego on the circlip Royce.......
did manage to jack out the bearing race , and ball bearings, looks as if the hub and bearing is all one piece?
Joined: Sat Aug 12, 2006 11:30 pm Posts: 6456 Location: Radelaide ofcourse!
 Posted: Mon Feb 10, 2014 8:35 pm |
Bearings can be bought seperately so you should be able to remove and swap. I just did mine a few weeks back and it cost bugger all more for the hub with bearings already pressed in.
_________________ Chop
gregwatkins75
 Posted: Mon Feb 10, 2014 8:44 pm |
fordem
Joined: Mon Apr 19, 2010 11:30 pm Posts: 2659 Location: Georgetown, Guyana
 Posted: Tue Feb 11, 2014 2:30 am |
There are two different styles - one has removable bearings, the other does not - I believe they are interchangeable.
klutched
Joined: Wed May 16, 2012 3:46 pm Posts: 1691 Location: Brisbane
Vehicle: 99 Grand Vitara
 Posted: Tue Feb 11, 2014 8:30 am |
My RHS hub didn't have a circlip on it, but it had the groove there so I went down and got one when I had a new bearing pressed in, cost $4. Pressing the old bearing out and new bearing in cost $10 and the bearing kit cost $55 posted off ebay, but if you want 2 you can get them for $100 http://www.ebay.com.au/itm/Front-Wheel- ... eca&_uhb=1fordem wrote: There are two different styles - one has removable bearings, the other does not - I believe they are interchangeable. So if you have the one without the removable bearing you have to get a whole new assembly? Also Greg make sure they're torqued up to 215nm I think it is or they'll keep blowing like mine...
gregwatkins75
 Posted: Tue Feb 11, 2014 9:13 pm |
Klutched try 155, instead, that's what the fsm suggests as mid range for torque..... I have one of the larger regular torque wrenches, cost a bit of coin, and it tops out at 200nm, that was the highest rating I could find without spending lots.... I really think most people would struggle to tighten a something to those pressures without a huge extension for leverage..
losfer
 Posted: Tue Feb 11, 2014 10:28 pm |
non replaceable bearing in a SQ vitara is news to me ...
magnat
Joined: Sat Jul 28, 2007 11:30 pm Posts: 1066 Location: Southern Highlands N
 Posted: Wed Feb 12, 2014 6:18 am |
The Ones for my 01 XL-7 were a Hub and bearing unit...
fordem
 Posted: Wed Feb 12, 2014 10:04 am |
losfer wrote: non replaceable bearing in a SQ vitara is news to me ... Attachment: GV_FRONT.jpg This is taken from the Suzuki Worldwide Electronic Parts Catalog and is from the Australian market section, an SQ420-2 to be specific.
klutched
 Posted: Wed Feb 12, 2014 12:09 pm |
gregwatkins75 wrote: Klutched try 155, instead, that's what the fsm suggests as mid range for torque..... I have one of the larger regular torque wrenches, cost a bit of coin, and it tops out at 200nm, that was the highest rating I could find without spending lots.... I really think most people would struggle to tighten a something to those pressures without a huge extension for leverage.. Just jumped on auto data and checked it up Front Hub torque should be 216nm OR 157LB/FT. Probably get onto that asap. I found $45 1/2" torque wrench that goes up to 210NM
schmiffee
Joined: Sun Jan 01, 2012 7:16 pm Posts: 123 Location: Gold Coast
 Posted: Tue Jun 30, 2015 9:03 pm |
Sorry to bring up an old topic, but I am looking at replacing the front wheel bearings on my 2003-2005 GV which comes as a complete hub/bearing assembly. However, I only JUST replaced these in April 2013!! Two years out of a set of bearings seems ridiculous to me. I am running slightly larger tyres (227/75/16), and I can understand that these would be putting more pivot load on the bearings/hubs, but I haven't heard of hubs being a problem before - just wondering if it is and I haven't heard of it, or my car is just screwed.
Last time I replaced them I purchased the bearing/hub assembly from Global Auto and installed them myself with the GV tool AND torque wrench - tried to do everything perfect so am a little bit puzzled particularly as I cannot justify $260+ every two years...
got_bar_work
Joined: Sat May 15, 2010 8:30 pm Posts: 2214 Location: Brisbane
 Posted: Wed Jul 01, 2015 4:52 pm |
U been playing in mud? Is the seals and bushes good on the up and cv Mud can kill bearings fast Ive done bearings in like 10k because of a damaged brass bush letting water in to the hub
schmiffee
 Posted: Wed Jul 01, 2015 9:48 pm |
The car hasn't been offroad once since I've owned it! The mechanic doing the aftermarket warranty service has said the last two visits that the wheel bearings have a bit of play in them...I might lift it tomorrow and check what they mean by 'a little bit', although I would prefer to have NO play at all when it comes to bearings... So I gauge it isn't a common issue then?? Maybe a dud set of bearings??
got_bar_work
 Posted: Thu Jul 02, 2015 5:30 am |
Mate had a new wheel bearing fail pink slip because of to much play. Not much u can do they are crap design. U cant adjust them
schmiffee
 Posted: Thu Jul 02, 2015 7:18 am |
Anyone got a recommended supplier then - not keen to go back to Global Auto...
schmiffee
 Posted: Sat Jul 18, 2015 12:59 pm |
Does anyone know if the bearings are replaceable in the 03-05 GV front wheel bearing/hub assembly. I called Suzuki and they reckon that they are, but from what I have read on here they aren't...I am tempted to believe here that knows what they are talking about rather than some numpty that can only read a computer parts manual...
got_bar_work
 Posted: Sat Jul 18, 2015 2:56 pm |
fordem
 Posted: Mon Jul 20, 2015 3:01 am |
fordem
 Posted: Mon Jul 20, 2015 3:03 am |
And the numpty with the computer, if given the vehicle chassis number, should be able to tell you what that particular vehicle was fitted with, when it left the factory
