It is currently Sun Oct 25, 2026 12:12 am
Vehicle: Suzuki Jimny
Post Posted: Tue Feb 11, 2014 7:58 pm
Is it wrong for me to put the old standard front springs in the rear? Because the rear springs I got are more like 80mm lift and it looked odd and was to ridged.
Its made the ride smother and the height pretty close to the front. Is this something people do often?
Vehicle: Suzuki Jimny 2010
Post Posted: Tue Feb 11, 2014 8:50 pm
Yeah it's been done before... I can't see any downside if it's sitting level... Measure from bottom of the rim to bottom of guard and check the difference in the front to back. If be interest to see how it sits. (Has to be level ground of course)
Post Posted: Tue Feb 11, 2014 8:51 pm
Also, are you sure the rear springs you were talking about... Are you sure they were for the rear? Fronts are a little longer ....
Post Posted: Tue Feb 11, 2014 8:56 pm
:thefinger: Yeh I'm pretty sure I have them the right way... these are the measurements I got so far (from top of the rim to guard)
stock.
F/L 195mm F/R 195mm
R/L 192mm R/R 192mm
Put the springs and shocks in the first time. got it all sorts of wrong
Post Posted: Tue Feb 11, 2014 8:59 pm
Is that pic from when you got it wrong? It "looks" to be pitching in the front a little there???
Post Posted: Tue Feb 11, 2014 9:04 pm
I swiftly fixed that... now my rear left hand spring was the long one. I then had
Tough dog all around:
F/L 255mm F/R 255mm
R/L 270mm R/R 275mm
Now with stock front in the rear it is:
F/L 250mm F/R 255
R/L 255mm R/R 245 (But Ill need to let it settle tomorow)
Post Posted: Tue Feb 11, 2014 9:05 pm
Yeh Fronts in the rear, Rear in the front haha
Post Posted: Tue Feb 11, 2014 9:06 pm
Sweet :) be interesting to see if it settles enough
Happens to the best of us ;)
Post Posted: Tue Feb 11, 2014 9:12 pm
Yeh, well I Had a google search before I did it and it said I needed the long spring in the front.. but it must be diffrent with a winch bar
Post Posted: Wed Feb 12, 2014 6:13 am
I had stock front springs in the rear of my old Jimny. They were all well and good until it was loaded up with camping gear where it handled liked Shit due to the soft spring rate, but that was a once in a blue moon id go camping. I ran 80mm springs in the front with 30mm spacers and it sat pretty close to level.
Post Posted: Wed Feb 12, 2014 5:31 pm
Ok, So they settled in and sat at
F/L 265 F/R 255
R/L 255 R/R 245
So I simply put a 8mm hub spacer between the rubber boot and cradle. (was all I had) bit dodgy haha.
But it all sits nice and level pretty much 255mm all around.
Post Posted: Wed Feb 12, 2014 5:36 pm
Post Posted: Wed Feb 12, 2014 6:17 pm
Looks a bit better :)
I would have thought the fronts would have handled a little more weight due to the weight of the motor etc up front... Although I spose they aren't a lifted spring either.
P.S. Monley... What happened to you on facey? You gone AWOL?
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Wed Feb 12, 2014 6:49 pm
andy is in hiding so he doesnt get fired from looking at his phone all day instead of pretending to weld
Post Posted: Wed Feb 12, 2014 6:52 pm
Yeh I was surprised it was as smooth as it was with the front sprngs in the rear... but a steal bar would be smoother then the Tough Dog "springs".
Post Posted: Wed Feb 12, 2014 7:36 pm
^^^What he said :lol:
Post Posted: Wed Feb 12, 2014 7:37 pm
:rofl:
Vehicle: 2012 Facelift Jimny JX
Post Posted: Tue Apr 14, 2015 6:06 am
F/L 265 F/R 255
R/L 255 R/R 245
Hi Grommet,
Do you still have your stock springs in the rear? How's the handling, as I'm considering doing the same. Based on what Monley says it wasn't so good when loaded up?
Users browsing this forum: No registered users and 145 guests
