It is currently Thu Oct 29, 2026 3:44 pm
Vehicle: Suzuki SJ70 & SJ51T
Post Posted: Wed Feb 12, 2014 6:26 pm
can anyone help me what i would like is some info on fitting a sierra motor maybe an 1.6 i have in the shed with a 5 speed, is it hard(posiable) without major mods
ps better put up a pic
Post Posted: Wed Feb 12, 2014 6:28 pm
not sure on 1.6 for the sierra or the lj yet maybe hamie down
Post Posted: Thu Feb 13, 2014 8:11 am
depends what you call major mods.
i have a j20a in my LJ81
Vehicle: Which one?
Post Posted: Thu Feb 13, 2014 8:16 am
tanshi wrote:
I have a j20a in my LJ81
8O
I'm green with envy.
Post Posted: Thu Feb 13, 2014 11:52 am
To fit the 1.6 you'l need to cut the gearbox crossmember out, make a new one and weld that in, get a custom jackshaft made, fit a body lift, fabricate new engine mounts, get some custom extractors made (unless you really luck out and find a set that fit, that's very unlikely though), find a way to fit a bigger radiator (if you do, brace up the mounts, mine had a corolla radiator and it cracked all the mounts off the body), cut a hole in the floor and probably do some panel beating to clear everything. It's a lot of work.
Just fit an F10a, it bolts in and you'l be able to do 110 just fine.
Post Posted: Thu Feb 13, 2014 4:32 pm
Ok cheers mite try to track down a 1L and do the internals up a bit
Vehicle: 95 sj70 and 78 lj81
Post Posted: Mon Feb 17, 2014 3:22 pm
Mine has a 16b, yes it is a lot of work but its worth it
Post Posted: Mon Feb 17, 2014 3:29 pm
Mite go a stock motor keeps it genuine (higher resale) as I mite sell once it's restored
Post Posted: Mon Feb 17, 2014 4:49 pm
I recon a 2.7 V6 will fit, with the right size shoe horn that is.
Post Posted: Mon Feb 17, 2014 4:59 pm
Thanks kenn want to do it?
Post Posted: Tue Feb 18, 2014 6:44 am
If only the engineer said yes all those years ago, I would have got myself a bigger shoe horn. :)
Post Posted: Tue Feb 18, 2014 6:51 am
need to move too QLD, if i could find a 2.7 it would already be in the car.
Vehicle: Which one?
Post Posted: Tue Feb 18, 2014 7:18 am
The 2.5's are a dime-a-dozen. Surely that'd be enough poke in an LJ anyway; do you really need the extra 200cc?
I assume it's just one of those "because I can" situations: an itch that can only be scratched with the H27A.
Post Posted: Tue Feb 18, 2014 8:01 am
exactly, realistically though the j20 will have more than enough breaking power might look at a bigger one down the track.
Vehicle: Which one?
Post Posted: Tue Feb 18, 2014 8:21 am
A J20/AW4 combo in a fiddy would make me happy in the pants.
Users browsing this forum: No registered users and 353 guests
