It is currently Fri Oct 30, 2026 10:58 am
Vehicle: 99 jimny
Post Posted: Wed Feb 19, 2014 8:26 pm
I want to turbo my g13bb jimny and I found a new turbo set up for a g16b, would there be any problems putting it on my engine or would it be bad?
Vehicle: '96 LWB trayback
Post Posted: Wed Feb 19, 2014 8:32 pm
If this is the question you need to ask, you're not up to the task of an aftermarket turbo conversion.
Vehicle: 99 jimny
Post Posted: Thu Feb 20, 2014 5:17 am
I'm not installing it, just buying the kit cheap, I just don't want to buy a kit that won't work.
Vehicle: 85 ' Drover
Post Posted: Thu Feb 20, 2014 8:09 am
What do you mean kit?
The easiest and probably most important part is does a g16b exhaust manifold match a g13bb. If it fits on, then you are one step towards it "fitting". It's a small step though.
Vehicle: 99 jimny
Post Posted: Thu Feb 20, 2014 8:31 am
Yes, that's the sort of thing I need to know, I haven't seen it yet, but if the exhaust manifolds match and the blocks are similar enough so all the plumbing will match up then I will probably get it
If all I need is an after market ecu or a remapping then its worthwhile.
But if too much stuff wont line up then its just an expensive turbo with a manifold and plumbing that will be of no use to me.
Post Posted: Thu Feb 20, 2014 8:36 am
As has been said, manifold- yes. Plumbing- not necessarily. There's front and side facing g16b inlet manifolds, but only front facing g13bb. Swapping inlet manifolds will likely mean sensor/computer changes.
All up it's going to be an expensive install in any case.
Vehicle: 99 jimny
Post Posted: Thu Feb 20, 2014 10:10 am
Thanks, that's about all I needed to know, if it would be feasible and cost effective.
From the sounds of it, it won't be.
Post Posted: Thu Feb 20, 2014 10:52 am
Plumbing and manifolds are cheap compared to the compressor and tuning, so I don't see the position of the throttle body being a big issue really.
Steve
Post Posted: Thu Feb 20, 2014 11:04 am
This business might do a kit for a g series motor.
http://www.bulletcars.com/superchargers/suzuki/
Users browsing this forum: No registered users and 354 guests
