It is currently Wed Oct 21, 2026 6:13 am
Post Posted: Thu Aug 20, 2009 10:48 pm
My LJ has a F10A motor and box in it, is there a tag on it somewhere telling you what year it is? i found the F10a stamp on it but havent found anything else yet.
Also is there any interchangeable parts motor wise with this and anything else? Or anything in particular i should know?
Cheers Shelby
Post Posted: Thu Aug 20, 2009 11:51 pm
I got 1litre extractors for sale if your interested. $50
Post Posted: Fri Aug 21, 2009 12:28 am
there won't be a tag on the motor, and an f10 is not standard. some f8 parts and late model maruti 1.0 litre stuff will fit.
Post Posted: Fri Aug 21, 2009 1:08 am
could you explain in a bit more depth joe about the F10A not being standar please?
also is there a 5 speed box for the 1lt's?
Post Posted: Fri Aug 21, 2009 1:15 am
the f10 would be out of a carry or a 1.0 litre zook. they are a good simple conversion from an f8 which would have been standard. the easiest (sort of) way to get a 5 speed behind a 1.0 litre is to get a maruti 4 speed box, which are basically a 1.3 box with no fifth gear and a 1.0 litre bellhousing, and transfer the guts of a 1.3 five speed into it. its a bit of work and you may find the f10 does not have adequate torque for the fifth gear.
Vehicle: LJ20 LJ50
Post Posted: Fri Aug 21, 2009 1:20 am
The LJ80 came out with the F8a which is a 800cc engine not a 1 litre. The F8 and F10 share many common components.
You can source a 5 speed from a JA11 jimny ( which is a sierra with a 660cc turbo engine) or you can use a maruti 4 speed and then add the fifth gear from a 1.3 box into it. Fatzook knows this mod pretty well.
Camels have nice toes
Post Posted: Fri Aug 21, 2009 1:21 am
oh ok, well the motor is out of a 1lt sierra and now sits in my LJ50 :D thanks for the more in depth description, but i think i'll just stick with putting a 80 t'case in it for now.
Users browsing this forum: No registered users and 129 guests
