It is currently Fri Oct 30, 2026 10:49 am
Vehicle: 2005 Suzuki Jimny JLX
Post Posted: Sun Mar 02, 2014 11:05 pm
Hi,
Looking at making a set of rock sliders for my Jimny and was just wondering if anyone has dimensions or plans in order to make a set. Any help with dimensions or plans would be really appreciated.
Thanks
Nick
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Mar 03, 2014 7:51 am
there's 2 ways of going about it, body mount mounted, or chassis mounted.
i recommend going chassis mounted, having had body mounted and they cause other problems.
Post Posted: Mon Mar 03, 2014 9:03 am
viewtopic.php?f=14&t=29326
Post Posted: Mon Mar 03, 2014 11:15 am
If you work out a decent way of attaching them to the chassis then let us know. I ended up welding mine on.
Post Posted: Mon Mar 03, 2014 11:26 am
I really like the way they have been mounted in the link Monley posted. I dont think they would cause problems.
monley wrote:
http://auszookers.com/forum/viewtopic.php?f=14&t=29326
I really like those sliders, might be the way I end up mounting it. Although I may make them a little bit more horizontal so they can still be used as side steps.
Seriously thinking of mounting them the same as the ones in the link that Monley posted.
Thanks for your responses
Post Posted: Mon Mar 03, 2014 11:28 am
Monely's link to them sliders don't work btw.
Thats my car before I bought it and I had to remake them due to the flex and them popping the door cards off.
Post Posted: Mon Mar 03, 2014 11:49 am
Ah ok, scratch that idea then. Maybe I could just use 3 u clamps to attach it. I'll have to have a look on my Jimny though and see if I can
Post Posted: Mon Mar 03, 2014 1:17 pm
Another one or two rails to the chassis wouldn't hurt including the bodymounts and if your running full plastics they would be off the door moulds more. I made them up high because the plastics were trashed/missing
Platinum Supporter
Platinum Supporter
Vehicle: 2010 jimny
Post Posted: Mon Mar 03, 2014 3:11 pm
yes it did...? dunno why u cant see it
BlueSuzy 's Jimny Rocksliders in Board index » Talking About Stuff » I made it and fabrication
its a better way then mine which were attached like this
the BlueSuzy method is what they should have been all allong and now im annoyed that i fergot about it....
Post Posted: Mon Mar 03, 2014 4:22 pm
Thanks for that Jezza, looks like that'll be the way I go, I'll add two 'u' shaped clamps in the middle too for a bit extra strength.
Post Posted: Tue Mar 11, 2014 11:34 pm
Mine are bolted to threaded plates (plate to plate) that are welded to the chassis. This allows easy removal and I have never stretched or stripped a bolt. Very solid.
Users browsing this forum: Google [Bot] and 337 guests
